tinkering with my 2022 laramie
it’s a carli suspension 2.5” lift in the front, 1” in the rear with king shocks and 35x12.5x18 toyo at3 on method 305s
Did you put carli’s HD springs in the rear? I’ve had the commuter series with HD springs on order for about 8 weeks now. Apparently serious supply chain issues with Fox 🤷🏻‍♂️
the kit didn’t give me an option to pick different springs from CJC offroad. i’ll have to check the boxes and see. i thought the entire kit—with the arms and kings came with the HD springs.
I think I had to order the Rebel kit to get the HD springs. Didn’t change overall numbers for me since my truck has the ORG. (Same factory height as the Rebel). Supposed to maintain 1-1.25” lift under 500 lbs constant load. May alleviate your need for a spacer.
you're right - i sent them a note and ordered the 500# constant load springs after a phone conversation with them. they'll be here mid-week next week. i'll get them under the truck next weekend.
Nice! Hopefully this will solve your issue. Looking forward to the results!
thanks! i'll be sure to throw up a post after they're in. headed to a friends shop on Monday to check the nitrogen charge in the rear shocks and the front coilovers too.
good news the HD springs are in. definitely a more firm ride now than it was. might be time to take a little tire pressure out. running 37 up front and 35 in the rear. going to play with that a bit. had to run to the office—i’ll
get a photo up later. happy to say the squat looks gone.
glad it worked out :)
