And the deer?
I see you got a piece of skin for your trophy wall.
Hit a small deer on my way home at 55mph. Took it like a champ. Active shutter seems broken and some sensors but otherwise we are good to go! Now to fork up the deductible and begin the fun process of getting it fixed.....
Gonna be expensive. At least it’s still drivable.
It’s what you don’t see that really starts adding up. Thought I just had a slightly shifted bumper once after hitting a deer but they ended up replacing most of the front end. All the mounts for lights/grill and bumper were broken after shifting at impact but looked fine visually from outside.
I agree. I thought it might not be to bad but that active shutter was no longer functional and cracked at the top. That piece alone is probably my deductible.
the button portion of your grill might be damaged too, from the picture the bumper looks to be touching it
Tinted the windows 15% on the front 2 to match the rear with a 5% front window strip to the AS1 line. Got Line X done in the bed, and gave her its first wash (Besides the dreaded wash at the dealership). 350 miles on the odometer now.
It looks like an easy swap in the video but I'm curious, is it fairly easy to do? Also, it seems these are much thinner than stock, is that true?
Very easy swap. Took about 5 minutes when I received mine the other day. It is a bit thinner, just seems more comfortable to carry.
