Ramroo
- Jul 1, 2018
I think he means the driver would be a poser.Hmm, let’s see…
TRX can actually go off road. Limited is a mall crawler.
Which one is the poser truck?
If so, then it was poorly worded.I think he means the driver would be a poser.
i should've checked with Sandi then.Nonsense, order from one of the discount dealers (Granger, Mark Dodge, Koons or Cummins), it could be 3 months or it could be 8 but it's never going to be 2 years.
The rebel is calling my name.I came within a hair of buying a PW. Reasons I didn't:
-PW has signficantly less payload capacity, and that means it's got much less legal towing capacity.
-PW gets miserable fuel economy with it's larger engine and 1,500 lbs. additional curb weight.
-PW can't be had with the 5'7" box, which means it won't fit in my garage at home.
-PW can't be had in the 5th gen body/cab.
RamboxesIf so, then it was poorly worded.
“TRX to me is the ultimate poser truck though.”
Yes, there are a lot of TRX owners who have never taken it off road or put anything in the bed. But the same holds true for every other series of Ram.
The TRX has every amenity that the Limited does, and more. Plus the racing engine, plus the better looks, plus the off road capability, plus similar or better payload capacity. And don’t forget the 10 mpg. That’s the best part.
Ok fine. And MFT. Both of which are options, not part of the Limited package.Ramboxes
also a superchargerOk fine. And MFT. Both of which are options, not part of the Limited package.
But the TRX has:
Performance drive modes (Baja, Snow, Mud, Auto, Custom, etc). Active dampening Bilstein shocks. A real shifter (no knob). Paddle shifters. No MDS or eTorque.
And the red start button that everyone wants!
It doesn't have a real shifter :-/Ok fine. And MFT. Both of which are options, not part of the Limited package.
But the TRX has:
what do you mean by not a real shifter? of course its not mecanic but electronic (so does most of the supercars), but it does workIt doesn't have a real shifter :-/
It's just a digital shifter in the center console from what I can tell. That's what the GT package has and it assume it is the same.
I just wanted the 6.2 supercharged in my 1500. Pass on the off road tires, no good for me on the roads.
Might be different if I lived in part of the country that was well, country.
I wasn't willing to spend $25,000ish for an engine upgrade and some mild creature comfort trade-offs
Yeah I mixed them up.Hmm, the PowerWagon certainly has Ram Boxes, the TRX does not unfortunately (about the only thing I miss)...
Depends on if you get the 5 seater or 6 seater (electronic or manual transfer case), my 2020 6 seater had tons of room in the front seats. But the backseat legroom on the 5th Gen 1500s is definitely larger than the 4th Gen cab using HDs no matter which version you get.Actually wait, are you LTD to PW guys or Rebel to PW guys sure the PW interior is smaller??? I thought the center console in the 1500 series trucks that goes all the way to the floor is removed from the PW??? Wouldn't that mean MORE leg room for stretching out...not less?
