SiriusXM streaming through truck's cellular stopped working
VectorZ
Alaska
Hey all, I have an odd issue. First off I live in Alaska where traditional satellite radio does not work. However for the past 2 1/2 years I have been streaming SiriusXM though my truck's cellular connection with no issues. In the past week the service stopped working. I tried resetting the radio and my account is current and paid through next year so it should be fine. Just wondering if any of you have had a similar problem and how it was resolved. The local dealer can't even look at it until mid-March, which is whole other topic...what's the point in having a factory warranty if you can't even use it for 3+ months!
vincentw56
Does it work on your phone without the trucks wifi? Have you tried to hook up and other device to the trucks wifi to verify its working? You might need to contact the cellular service you are using for the truck. AT&T calls it connected car. Mine stopped working after an update and they say I can't get it because of a Uconnect bug that is being worked on.
VectorZ
Alaska
Yes it works fine on my phone, the cellular the truck was using was not a paid service, it just worked with the SiriusXM service.
vincentw56
Is your truck new? Maybe you had a trial of cellular service and it expired. I had a trial when I bought my truck.
VectorZ
Alaska
Clearly they changed something. You will need to call Uconnect customer service to see.
Didn't think about calling them. The issue I am repeatedly running into is that nobody knows (including dealership employees) that you can stream through the vehicle itself.
Jimmy07
Honorary Site Supporter
I think you mean that you’ve been using the radio’s WiFi hotspot to stream SiriusXM?
That’s how it works when you lose satellite reception, it will switch to streaming if there is an active WiFi hotspot. I’ve heard of people just having the WiFi active without paying for the service, and I had a 12” transplanted radio that was like that. Sounds like they finally caught on and killed your active WiFi.
VectorZ
Alaska
Maybe? Like I said I have never paid for the Hotspot service and assumed it just worked with the paid car streaming service since that is a different charge than just home access.
