Sigh… first problems with my 2022 Rebel :(
Thatjusthappened82
Drove into town today, parked… prompted me for an OTA software update, so I did that then spent 2 hours doing errands. Came back to my truck… remote start didn’t work, ok figured I was too far away, no big deal. Hop up in the cab, hit the button and the CEL comes on!!
Immediately drove to the dealer and they scanned it and said “hey this is weird… looks like an O2 sensor fault, but it’s also showing as active”.
So now my RAM app says I have an engine malfunction EOBD/Injection System Failure, CEL stays on, and remote start doesn’t work from the app or fob. Have an appointment Tuesday, but truck only has 3200 miles on it and I’m sad.
Dewey
WI
Great. I just had an OTA update.😖
I know it said some features might not work for up to 24 hrs but sounds like a totally different issue there. Hard to believe it’s a coincidence though.🤔
MXZGUY
Wisconsin
Great that sucks. But if you have the gasser maybe the OTA was for a diesel, and you received the wrong one. Maybe over thinking also
Remote start will not work when there is a check engine light on
Ram-a-Kin
I got the OTA Update message the other day when I parked my car. Today I received an email from RAM Service stating “Vehicle Malfunction Indicator Light Alert” and to schedule maintenance immediately. It also states to view full info on your Dashboard. I logged in to the app and its states the same as @Thatjusthappened82 - EOBD/Injection System Failure and references turning the key to MAR (driving position) and also states that “Traffic Wardens are authorized to check that this warding light is in working order.” Traffic Wardens?????? My remote start does work though. I also do not have any dash warning lights displayed.
@RamCares any Ideas???
Thatjusthappened82
Dealer just called and said that my fluidfilm application from months ago caused a NOX sensor issue and wouldn’t be warrantied? That doesn’t sound right.
Cbty2050
Dealer just called and said that my fluidfilm application from months ago caused a knock sensor issue and wouldn’t be warrantied? That doesn’t sound right.
"Knock" or "NOx" sensor? Fluidfilm, like an undercoating goo?
Thatjusthappened82
Yeah, he said knock but he must have meant NOX since it’s a diesel. Yes fluid film is a rust preventative undercoating for the winter salt/brine. Either way fluidfilm is basically a thin solvent free dielectric grease. If that causes a NOX sensor failure, I’m worried what road salt and snow will do.
Cbty2050
Do you know what the code was/is? There was an update for NOx sensor performance code. The dealer needs to prove it caused the code to set.
  • tsb18-133-22.pdf
BB22
About 2 months ago, I was parked with the engine off, but the start button was in the "on" position for about 10 minutes so I could make some setting adjustments that require the start button to be in the "On " position. The engine light remains illuminated when the start button is in the "on" position. The very next day after driving to work, I got an email like you got with the same EOBD/Injection System Failure. There was nothing at all wrong with my Rebel. No check engine light and everything worked great. The Ram Connect app does a monthly Health Report and shows the malfunction warning just like the email. Two weeks after the initial warning, the new Health Report was clear. No malfunctions showing. This past Friday I was once again changing some settings with the Start button in the on position for 5-10 minutes. Guess what, another email showing the same malfunction once again. I'm certain that once the system detects that the engine light is on for more than a minute or so, it thinks there is a malfunction and sends the email warning even though there is no actual problem. Most likely just a glitch in the detection system. The warning will clear as soon as the next Health Check occurs.
argus
Registered just to say thanks! Confirmed my suspicion as I had this identical situation with my truck/app as well.
