bhardy5005
- May 26, 2019
I've posted about this before and if it's on another thread please let me know. My 2019 Big Horn hasn't alway been this way but now whenever I'm running the ac or heat and pulling in outside air, I hear air around the door seals. I'm not sure if it's air escaping or coming in. The pressure in my ears change as well when I shift between recirculate or fresh air so I feel like there should be a vent inside the cab that releases air once I pull in outside air to equalize the pressure. When running in "air recirculation" mode, everything is fine. I can put my fingertips against the door seals at the top and when I switch to "outside air", the doors actually push out just a little. I've had others in my truck and all four doors do the same thing. Any help would be appreciated.
