Neat idea, but a little "much" for me.Made a nice little mod today. Brighter than I thought but really like the look.
Got a link to the product and do they have different item's available?
					fluxgeare.com
				Where did you tap that into under the hood?It’s actual one size. Just measured and made sure it was center.![]()
Flux Geare
fluxgeare.com
I used add a micro circuit for positive and ring terminal on negative. Also a couple of photos of how strip is placed. You don’t just lay against black plastic or it will get cover by black seal on hood.Where did you tap that into under the hood?
		It is a micro fuse. You can get at almost any auto parts store. I just showed them the Amazon photo I posted and they got them for me. I actually used F60 and hope other photo shows you how I placed micro circuit. It has a 20amp I added another 20 amp. Overkill but have had no issues. I’m going to notch out side of cover so lid will lock when I get a chance.Battman:
I agree this is very cool and I would like to try it myself but I am not a "car guy" so I need a little more explanation.
It appears you are tapping into the external fuse box using a fuse tap. Do you have a specific part number and/or source for the tap you used or can you give me the parameters (apparently there are various types like ATC, Micro2 etc. and different amps).
Then it looks from your photo that you tapped into slot F54 (15A, PCM). Is that correct? Did you have to do anything with the fuses already in F59 and F60?
Any explanation you could provide would be very much appreciated! Thanks for sharing.
Paul
Which is the Amazon unit?Mine just came in.
Looks like it was from Aliexpress.
I just checked Amazon with the numbers on the box and looks like it's cheaper from Amazon and has a selection of colors. This Flux Greare guy\website is just some random drop shipper.
On the side of the box it shows the different colors you can get it in, just not from this drop shipper.
It does explain why this guys website showed the bar in what seemed to be a blue color, despite him not selling it in blue. He just stole pictures from over the internet of people with the kind of bar and threw it up.
Oh well $35 and a learned experience.
Just search for "led hood light"Which is the Amazon unit?
What fuse would you recommend tapping into?I just ordered one. for $35 it's worth the risk.
Really wish it came in amber to match my DRL
Not sure where I will wire it into. I don't want it sharing a fuse with the PCM encase the light malfunctions and pops the fuse while the truck is running.
