Adding 360 Surround camera for 2019-21 1500 Rebel
AlexMaxiMen
Hello! Does it possible to add and install the 360 view system for my 2019 Rebel with 4C 12 inch Uconnect? If Yes, what i need to do and bought?
Toperz
Stratford, CT
yes. its possible and could be expensive.
most likely you gonna need front camera, front emblem backing plate for camera mounting, back camera(that one without 360 what you may have its not gonna work)+tailgate handle for 360camera, side mirrors with cameras, video cables(fakra) long enough to run from the front grille to inside cabin and from driver side to passanger x2, CVPM module+harness from our member here Jimmy07(my recommendation), brackets for mounting front and back cameras(mine did not came with), software(alfaOBD) and hardware(OBDlink MX+) to enable 360view.
lots of patience when doing install.
AlexMaxiMen
Ok. But, why stock rear view camera dont work with 360 view?
Who can post the list with part number what to need?
Toperz
Stratford, CT
360 camera is bigger. I'll see if can find list parts what I've used for mine truck, it should work with yours too.
E1NSER
People's Republic of Massachusetts
Was there a walkthrough you followed at all? I remember someone a few months ago was working on tackling this but forgot who it was. Thanks
Toperz
Stratford, CT
I didn't have any walkthrough to follow. Just was searching for parts and watch youtube videos how to remove door panels, front grill, rear tailgate handle.
But yes there was someone who add 360 camera and he listed parts. I've used some from that list.
  • 360 camera.pdf
Piotr_Rebel
UAE - Abu Dhabi
I'm in the process of collecting parts for same upgrade on my 2022 Rebel GT. Attached list in pdf is not correct. 68320948AL is DASM camera that is not part of 360 view camera system, also door modules are not required.
In regards to rear camera, that is correct, it is bigger than rear view camera system, but along with camera tailgate handle need to be replaced (360 camera has bigger diameter and its longer)
St-na
Houston
Did You finish Your list?
Piotr_Rebel
UAE - Abu Dhabi
I've ordered tailgate handle Part Number: 7KJ42LAUAA (in my case for multi-function tailgate - Cristal Granite color)
Just today harness for CVPM and BSM arrived from Jimmy07.
So far I was able to install cameras into side mirrors and harnesses for cameras and BSM lamp. (I prefer to keep my original mirror body with no scratches on the covers, that is why I've only replaced internal parts and mirror glass)
CVPM part no is 56029964AF
For the front camera I'v bought Front Camera Assembly for RAM LIMITED (including camera plinth, jumper wire, camera bracket and camera) I've cut original Rebel grill to match camera bracket (see photos)
LIMITED Camera plinth.jpeg Camera plinth cut piece.jpeg REBEL grill cut.jpeg REBEL grill with camera add-on.jpeg Camera add-on fixture.jpeg REBEL Grill with camera.jpeg
I've made probably small mistake with camera cables order (I've ordered Fakra-Z cables as per length, but front cable was to short to route it as it is by factory. I've routed directly to passenger side where CVPM is mounted) I'll confirm cable lengths after all is connected.)
Hopefully during next few days I'll connect power and CANbus to CVPM and do configuration with Alfa OBD.
I'll update with results.
Argondizza
Did you have to cut out the mirrors for the cameras to go in? I’m looking to do the same on mine since I have a BTS with plastic mirrors I probably won’t find the with cameras built in
Toperz
Stratford, CT
You maybe able ti get parts without cutting. Look for 360 limited mirrors
Piotr_Rebel
UAE - Abu Dhabi
Yes, I've drilled only bottom of the mirror. There is no other cutting needed.
Parts required are:
- camera
- camera bracket + screw
- Fakra jumper cable
P.S. If you get used mirrors with chrome covers you can replace them with black from your mirrors. (easy to remove and install after mirror glass removal, which is a bit tricky to remove)
mjdrebel
Parts required are:
- camera
View attachment 145482 View attachment 145483
Hi Piotr_Rebel,
Please can you advise me on my plan to 360 Surround System to my 2021 Ram Rebel with the 12inch. What would your recommendations would be regarding the side mirrors? Buy a set of limited or drill like you are doing?
Please can you confirm the parts needed.
Can I message or contact you directly?
vincentw56
I added a HOW TO on this. It isn't very detailed yet, but it is a start.
mjdrebel
Is this HOW TO FOR A REBEL?
Piotr_Rebel
UAE - Abu Dhabi
General sequence is same, but front grill is solid one piece, does not have seperate plinth for logo/camera, I think Rebel grill with camera does not exist. If you want to keep Rebel grill you need to DIY camera bracket (what I did)
Other option is to replace complete Rebel grill with Limited version.
Toperz
Stratford, CT
Hi Piotr_Rebel,
If you get Limited mirrors, both of them auto dim(at least mine do) have blind spot warning, heated, power fold, puddle light and no drilling BUT you may have to get new door modules(I didn't have to). I've bought mine for $400 a pair(used but excellent condition). Just my 2 cents.
mjdrebel
What Ram 1500 do you have? What have you done in regards to 360 Surround Camera System, Adaptive and Lane Assist?
