AlexMaxiMen
- Dec 24, 2018
Hello! Does it possible to add and install the 360 view system for my 2019 Rebel with 4C 12 inch Uconnect? If Yes, what i need to do and bought?
yes. its possible and could be expensive.Hello! Does it possible to add and install the 360 view system for my 2019 Rebel with 4C 12 inch Uconnect? If Yes, what i need to do and bought?
Ok. But, why stock rear view camera dont work with 360 view?yes. its possible and could be expensive.
most likely you gonna need front camera, front emblem backing plate for camera mounting, back camera(that one without 360 what you may have its not gonna work)+tailgate handle for 360camera, side mirrors with cameras, video cables(fakra) long enough to run from the front grille to inside cabin and from driver side to passanger x2, CVPM module+harness from our member here Jimmy07(my recommendation), brackets for mounting front and back cameras(mine did not came with), software(alfaOBD) and hardware(OBDlink MX+) to enable 360view.
lots of patience when doing install.
360 camera is bigger. I'll see if can find list parts what I've used for mine truck, it should work with yours too.Ok. But, why stock rear view camera dont work with 360 view?
Who can post the list with part number what to need?
Was there a walkthrough you followed at all? I remember someone a few months ago was working on tackling this but forgot who it was. Thanks360 camera is bigger. I'll see if can find list parts what I've used for mine truck, it should work with yours too.
I didn't have any walkthrough to follow. Just was searching for parts and watch youtube videos how to remove door panels, front grill, rear tailgate handle.Was there a walkthrough you followed at all? I remember someone a few months ago was working on tackling this but forgot who it was. Thanks
Did You finish Your list?I'm in the process of collecting parts for same upgrade on my 2022 Rebel GT. Attached list in pdf is not correct. 68320948AL is DASM camera that is not part of 360 view camera system, also door modules are not required.
In regards to rear camera, that is correct, it is bigger than rear view camera system, but along with camera tailgate handle need to be replaced (360 camera has bigger diameter and its longer)
I've ordered tailgate handle Part Number: 7KJ42LAUAA (in my case for multi-function tailgate - Cristal Granite color)Did You finish Your list?
You maybe able ti get parts without cutting. Look for 360 limited mirrorsDid you have to cut out the mirrors for the cameras to go in? I’m looking to do the same on mine since I have a BTS with plastic mirrors I probably won’t find the with cameras built in
Yes, I've drilled only bottom of the mirror. There is no other cutting needed.Did you have to cut out the mirrors for the cameras to go in? I’m looking to do the same on mine since I have a BTS with plastic mirrors I probably won’t find the with cameras built in
Hi Piotr_Rebel,Yes, I've drilled only bottom of the mirror. There is no other cutting needed.
Parts required are:
- camera
- camera bracket + screw
- Fakra jumper cable
View attachment 145482View attachment 145483
P.S. If you get used mirrors with chrome covers you can replace them with black from your mirrors. (easy to remove and install after mirror glass removal, which is a bit tricky to remove)
Is this HOW TO FOR A REBEL?I added a HOW TO on this. It isn't very detailed yet, but it is a start.
HOW TO: Add 360 Surround View Camera System
After installing the 360 Surroundview Camera System, I decided to put this together to help others. I know there are several others who have done this. If you have any extra input, please let me know. I will start with the parts list first. Make sure to read the notes. You may need to find the...5thgenrams.com
Should be the same. I'm not sure how it would be diffirent except maybe the front camera.Is this HOW TO FOR A REBEL?
Hi Piotr_Rebel,
Please can you advise me on my plan to 360 Surround System to my 2021 Ram Rebel with the 12inch. What would your recommendations would be regarding the side mirrors? Buy a set of limited or drill like you are doing?
Please can you confirm the parts needed.
Can I message or contact you directly?
What Ram 1500 do you have? What have you done in regards to 360 Surround Camera System, Adaptive and Lane Assist?If you get Limited mirrors, both of them auto dim(at least mine do) have blind spot warning, heated, power fold, puddle light and no drilling BUT you may have to get new door modules(I didn't have to). I've bought mine for $400 a pair(used but excellent condition). Just my 2 cents.
