Installed Rough Country 2inch strut lift in the front. Now it looks like the back needs about a 1 inch lift. Should i wait till after i put spacers in the rear to get alignment done ? Or is ok to do the front wheel alignment.
Post back on the ride after a break in period. Looking at the same set up.
How long are we talking about waiting? A couple days -- who cares? A month -- get it aligned.
I can't imagine a 2" lift not affecting camber so you'll need an alignment and you'll end up paying for a second alignment later.
If I remember my Trigonometry, 1" rise on a 145" wheelbase equals 1.2 degrees. So if you get it aligned now, your Caster will be off by that much when the rear is done. Will it affect tire wear? Probably not. But since they work the two eccentrics to adjust Caster and Camber together, it's gonna affect things.
Installed carbon fiber steering wheel w/heat. Ebay, shipped from China, same factory that supplies US, about $300 less than US distributors. Uses factory frame. Heating connectors are not factory, so some splicing is required.
I heard they come with two different ways to mount the top bolt on the frame. The same way as factory or drill out the threads in the frame and mount their way. Is this true?
They come with an extra pair of bushings & bolts in smaller sizes if you want to install them the same way as factory (using the welded nut on the frame).
I used the smaller bushings with the factory bolts and it worked out great. Mounted right up to the Hellwig with no issues.
Nice!!
Did you paint the ram head on the airbag or is that an overlay?
Sent from my SM-G781U1 using Tapatalk
For 2022 the emblem is black on night edition. I put the black one in my Laramie, but I wanted the black shifter knob cap to match. I can’t figure out how to get one without ordering the whole shifter unit.
How did you swap out the ram emblem on the wheel? I thought it was part of the air bag system...
I dont really have to drive the truck much i have two other cars and im gonna buy bigger tires in a month or so.
Installed SDHQ Ditch light Brackets and reinstalled my old BD Squadron Sports and TRAM HAM Antenna that I took off from my 4Runner. I should've bought new Squadron faceplates and new antenna but... why waste money just to look good? Not like Im sponsored or anything.
Also installed SDHQ Terminal kit to clean up my wiring at the battery, since I need to add one more power cable from battery and will need multiple grounds for all the lights and stuff I planned to add.
Finally, extended and hid the ditch light wires as the originally supplied harness was not long enough for a full size truck. I took off the plastic plugs and hid all the wires under the plastic cover. There are plenty of room under the plastic cover for that.
thumbnail_IMG_2907.jpgthumbnail_IMG_2908.jpgthumbnail_IMG_2909.jpgthumbnail_IMG_2910.jpgthumbnail_IMG_2911.jpgthumbnail_IMG_2912.jpgthumbnail_IMG_2913.jpg
View attachment 145311View attachment 145312View attachment 145313View attachment 145314View attachment 145315View attachment 145316View attachment 145317
I forgot to add: i also didmy 500 mile oil change. Was supposed to do it before Thanksgiving but shop was closed and I don't have the keys, and we've been busy after Thanksgiving. Ended up changing the oil and filter at 800 miles.
Oil looked very clean.
