Added some reverse lights today
Rmazzei
general question. i wires reverse lights using the 7 pin adapter and when in reverse (Led lights on) radio signal is dramatically worse. once I am out of reverse and lights are off radio static is gone. Any ideas?
John Jensen
San Diego
Sometimes it's a ground fault. Try changing your LED's ground from the 7-pin adapter harness to grounding your LEDs to the truck metal or frame.
5thgenalamode
Ravenna Ohio
I haven’t had that issue. Make sure you have a good ground. I ground my lights to a bumper bolt, and prepped the area well for a proper ground.
WildWildWest
South Carolina
Parts list
MICTUNING Flush Mount Led Pods, 2Pcs 20W Flood Cree Led MICTUNING Flush Mount Led Pods,... https://www.amazon.com/dp/B078WNM3K9?ref=ppx_pop_mob_ap_share
7 pin t harness, I used this one CURT 56584 Replacement... https://www.amazon.com/dp/B007EA6WQU?ref=ppx_pop_mob_ap_share
5way trailer side wire harness, I just used this and cut it for my needs CURT 58550 Vehicle-Side and... https://www.amazon.com/dp/B001EOV2X0?ref=ppx_pop_mob_ap_share
Waterproof heat shrink tubing
Solder if soldering the wires or butt connectors
Wire harness tape
Zip ties
Ring terminal for ground wire.
External tooth lock washer for ground.
This is awesome and looks great!! I understand they are getting their power from the trailer light harness, how are they told to turn on? Sorry if an amateur question! Lol
Jako
Borough of Parks
FYI
Lpsouth1978
The install went well. You will notice that I have some additional (Larger) lights also, but those are on a switch in the cab. I use those for camping, working in the backyard, or other projects after dark, etc. I wanted to do this install so the lights are automatically turned on for backing. I really like having both sets, and the larger lights can be turned on without the truck running if needed.
20220930_150011.jpg 20220930_150016.jpg 20220930_150212.jpg 20220930_150242.jpg
theblet
View attachment 142408 View attachment 142409 View attachment 142410 View attachment 142411
Wow nice! So behind the bumper you install the 7 pin T harness, and plug the 5way trailer side into it and wire the lights to this?
Lpsouth1978
Yup. Super easy. I just cut off all of the un-needed wires from the 5 way harness, zip tied the wires up and out of the way, and done. The most difficult part was removing the little plastic pieces from the truck to cut the holes out. It wasn't hard, but there isn't much room to get a socket on the bolt by the exhaust. It is easiest to remove the spare tire and move the exhaust tips out of the way.
theblet
Sweet. Thanks! No relay needed?
theblet
I was wondering if you could install the 5way trailer side wire harness in line in the back of the bumper, or does this connector just come from the 7 way harness? Thanks
