Mopar_maxi
- Feb 22, 2020
It’s the cut kit. I modified them and cut off the upper mounts on the IHC brackets so I only relocated my lower control arms for better separation at the track for traction. The core arms aren’t special, they work with the factory brackets or the cut kit.Is that the "cut" bracket or the bolt on? Hard to see on the phone. If its the cut bracket did you spec that with CORE 4x4 or...?
