2020 Rebel Finally Lifted (6" Rough Country Vertex on 37's)
NoOtherHobby
Just got my truck back from the shop and am very happy with the result. I have a 2020 Ram Rebel. I had the shop install a 6" Rough Country lift with Vertex coils/shocks. Wheels are 20x9.5 -18 Black Rhino Barstow. Tires I went with Mickey Thompson Baja Boss A/T in a 37x12.5. Also added a AWE 0FG cat-back with 5" black tips and Westin Outlaw running boards. Had to trim the liners and pinch weld but otherwise I have no rubbing driving around town. I did notice some rub at full lock when going over big bumps so I will see if I can manage to correct that but it isn't causing me much concern. Calibrated tire size with the Tazer DT. Truck is driving great and exhaust sounds the way it should during throttle and near silent while cruising. Need to get on the freeway to see higher speed performance / sound but around town has been a blast. Apologies if this should be posted on another board.
skyhawk42
1 word…Jealous. Can’t wait til I take the plunge and make mine look that good
PDiddy
Looks awesome. I’m sure it looks even better in person. I like that the wheels don’t poke out much. Real clean looking.
Av1
View attachment 141916 View attachment 141919
That looks great! I like the wheel and offset, especially that it doesn't stick out much.
Does it fit in your garage with the height? It's hard to tell, but it looks like you may have 8' tall garage doors.
You have good taste.
NoOtherHobby
Thanks for the kind words. I wanted a little poke but didn't want a bulldog stance. I like how it came out. Only took 2 years of research (and saving). It does fit in the garage and yes, I do have 8' doors. I need to measure but I believe my height is around 85"-86".
NoOtherHobby
Wonder how much that will ditch you gas mileage . . . .
We'll soon find out. Best way I can describe the truck is that it doesn't feel as light on its feet. Maintaining cruising speed requires a few more drops into 6th and 7th than with the factory 33" Duratracs. I was averaging around 15mpg and I'm guessing I'll drop to about 12mpg based on current performance. That being said, I only put 7,500 miles per year on the truck so MPG wasn't a significant concern when going to 37s. Biggest concern now is rub at full lock over bumps but that's the trade off I chose for the look.
PDiddy
12mpg sounds about right, coming form 15. Still better than the TRX. Lol
