Finally got the Ram Air
Nick57
So I finally got an installed that Ram Air on my truck. To my shock there is a noticeable difference in the responsiveness in the throttle. It also appears that I've gotten a small bump in fuel economy. I honestly only purchased it because I love the way they look and was hoping for slightly better fuel economy. If you're looking for a nice little upgrade I def recommend doing it. Small install tip, do not fully remove the rear engine cover. You only need to remove the 2 bolts and lift it up to replace the hose. I pulled mine all the way out and it was a royal pain to get it back in place. lol
djevox
VP of Creative Thinking
MD
Awesome, congrats 👍
deepc6
I like the sound when the throttle is around 2500-3000 rpm.
Nick57
56 Pontiac Thanks for posting pictures. For some reason I neglected to even take pictures! lol​
utlong31
Where can I get one. I was thinking about a CAI but this looks really clean.
lawmann8
I installed a RAM Air Intake also and noticed the improved throttle response and increase in MPG. I’m actually getting 21-23 MPG on the hit cruising at 70MPH.
lawmann8
I have a 2022 Ram 1500 Laramie 5.7 Hemi 4x4 with factory air suspension.
Fast6.3
I was thinking of getting the vararam but this looks much cleaner.
Derrick_Cyr81
I got a used one for my truck from eBay. When you installed yours what type of retainers hold the front panel to the radiator support? There are square holes in the support
Dewey
WI
The same push pins that are used for the stock radiator cover panel. You have to re-use them. I bought a flat trim tool to pop them out without damaging and it worked well.
Derrick_Cyr81
It’s the piece that says ram, there are 2 bolt holes towards the front of it that looks like it bolts to the upper bar of the radiator support, they are square holes in the support right in that area. I know the upper shroud gets held on with push darts
Darksteel165
Massachusetts
It's better and cleaner. But almost twice the price.
You mean almost 3 times the price.
Vararam is $320, Ram Air intake is around $800.
I also don't see how it can be "better" they are both the same thing essentially besides looks.
You can also use any size pushclip that fits, doesn't need to be OEM if you lost them. Can get them cheap off ebay.
mikeru82
The Palouse
Anyone who claims faster throttle response is smoking something I'd like to partake in myself. Or trying to justify spending so much on an intake. I would have loved it if it did give any performance gains, but after having one myself I can say there is no discernable difference in performance. The only thing this intake does is to change the sound you hear when the throttle body opens up, giving a nice butt dyno effect.
Dewey
WI
I used all the stock push pins and every hole was filled. Actually you will end up with two spares when done as stock requires more.
Darksteel165
Massachusetts
