2021 RAM 1500 Limted Tire Options W/ Stock Rims
gbordelon2000
My OEM tires are shot. I actually like the stock 22" Rims. The current Goodyear Eagle Touring 285/45-22 are what came on the truck. I like the look AT tires like this one Nitto Terra Grappler G2. My question is can I go with a larger tire without any mods to the suspension? Like a 285/55-22? Has any one done this to their RAM?
I just did exactly what your asking only with toyo open country AT3. I have only a couple minor issues. Tire noise is moderate and I do have front tire rub when I turn full left or right going forward or backwards. My truck is a 2021 Ram Laramie Sport with 4×4 air ride suspension. I went from 285/45/22 to to 285/55/22.
Thanks for the information! I think I'm going to pull the trigger and do the same. To be clear you didnt have to modfiy suspension or remove anything right? Do you know if there is anything that can be done for the rubbing? Or in your opinion its really not a big deal?
I just saw this February 8th 2023. Was never notified that you responded. Sorry for this extremely late response. I haven't made any modifications however I'm thinking about trimming inside wheel wells on the fronts. Make sure you get tires Road forced balance otherwise you will be fighting vibration issues with the TOYO open country AT3 tires.
