- Jul 25, 2020
PB Blaster really isn't lubricant. It's a penetrating oil. It may actually loosen up debris and make it worse. I havent tried taking mine apart to see about lubrication. Mainly because it still operates fine.I was able to get to it. I disconnected the strut. There still seems to be some resistance in the drivers side hinge tho. I also hear a slight squeak on that side. I lubes it a bit with pb blaster. It’s a bit better but not fluent. Sucks that the tire throws mud and water directly at this spot. What were the designers thinking? What’s the best way to lube the hinge?
