First post and it's asking about MPG after boosting a truck. LOL That's awesome! Welcome aboard! Being serious though, I have seen/heard of MPGs going up after boost.With all of those added horses, what kind of MPG's are you getting?
I just bought my 2019 Tradesman 1500, I'm coming from a 1997 F350 with a supercharged 460. I only asked because I got the same mileage (although mpg in a 460 truck is horrid) with a Vortech V1 unless I totally put my foot to the floor. Love my truck, but I'm sick of working on it and going from a 1 ton to a 1/2 ton seemed like a no brainer if it can out tow my old rig.First post and it's asking about MPG after boosting a truck. LOL That's awesome! Welcome aboard! Being serious though, I have seen/heard of MPGs going up after boost.
14 or so and keep in mind I’m leveled with big heavy wheels and tiresWith all of those added horses, what kind of MPG's are you getting?
Did you ever get an answer? And did you decide on Whipple vs. ProCharger?PM sent
Sent from my SM-N976U using Tapatalk
Hi im new to the group. What did the whipple cost? I have been all over the internet and they all have diffrent prices on the same whipple supercharger. And what are the gains?I have already installed a Whipple on my 2019 Ram 1500 Limited, with a custom tune in addition to a few other mods like a Borla exhaust. Why do you need to go for ProCharger?
The computer has to be unlocked by Diablo for the procharger kit unless you do the tuner version then you can have it tuned with hptuners or diabloDid you ever get an answer? And did you decide on Whipple vs. ProCharger?
I just bought a HEMI eTorque. I am eyeballing this one here from ProCharger:
ProCharger 1DP415-SCI Stage II Intercooled Supercharger System for 19-22 RAM 1500 5.7L VVT HEMI eTorque
ProCharger 1DP415-SCI Stage II Intercooled Supercharger System for 19-22 RAM 1500 5.7L VVT HEMI eTorquehighhorseperformance.com
Looking to better understand what needs to be done with the computer while installing this. Anyone done this themselves? OR that have been explained from a shop what would be required to be done?
How much was the whipple supercharger kit? And the install?I have already installed a Whipple on my 2019 Ram 1500 Limited, with a custom tune in addition to a few other mods like a Borla exhaust. Why do you need to go for ProCharger?
I'm trying to supercharge my 2019 ram rebel i already have the unlocked pcm and trinity 2 tuner with a custom tune from hemifever. It gave me a noticeable diffrence in power but not enough i want more. I'm trying to get to the point where i can run low to mid 12's on the quarter mile. Any suggestions or recommendations on what platform i should go with ?
Im only running an unlocked pcm with trinity 2 tuner with a hemifever 93 octane tune i and half gallon of jet fuel. And a borla attack exhaust im doing 12.8 was my best so far on 4high running it on 2wd its a 13.2 1/4 mile im also running stock tires so no grip basicallyWhat do you run in the 1/4 now?
What did the kit cost? And try a bigger pulley it will increase the hp and tq along with the amount of whine the more boost the higher the supercharger whime also run and intake if you are using the stock intake coversion.I've just had a Harrop supercharger installed. I like it but it's really quiet, almost no blower whine.
If you drive your truck the same, you should get pretty close to the same gas mileage you were getting before installing one.
TVS2650 RAM 1500
Harrop has given the RAM 1500 utility the boost that it needed with the release of our TVS2650 Supercharger kit, utilising the largest, most-efficient rotating group ever produced by Eaton.www.harrop.com.au
You use a smaller pulley in the blower for more boostWhat did the kit cost? And try a bigger pulley it will increase the hp and tq along with the amount of whine the more boost the higher the supercharger whime also run and intake if you are using the stock intake coversion.
What's the point of adding 1/2 gallon of jet fuel? And when you say jet fuel, do you mean like JP-8?Im only running an unlocked pcm with trinity 2 tuner with a hemifever 93 octane tune i and half gallon of jet fuel. And a borla attack exhaust im doing 12.8 was my best so far on 4high running it on 2wd its a 13.2 1/4 mile im also running stock tires so no grip basically
Yeah, which is why I was askingNo way is he running jet fuel in his truck. It would be similar to adding a half gallon of diesel fuel. He's got to be adding a half gallon of 100LL.
Boost levels depend on how the engine is built and compression ratio. When building a stroker, you can set the compression to whatever you want . If you are planning on booster you use a lower compression ratio, which allows you to run higher boost more safely. Simply being a stroker motor doesn't mean high compressionI have been curious to the ones which are running Whipple/Procharger/etc on stock-ish (not stroked) 5.7 hemi - what are the 0-60 times & what are the 1/4 mile times you are getting?
Reason I asked is because usually you can run more boost based on stock compression compared to a stroked motor, which usually results in less money spent & if/when the supercharger fails you can simply remove it & have a dependable stock engine to still get around on. “Typically” but not always as each build is different, I know. I put a ton of miles on my truck in short amount of times though (14K since April 8th 2022), so my situation is a little different than most.
