JC Ramirez
- Jun 27, 2022
Hello everyone, new here at the RAM WORLD. How do i deactivate the DARN annoying braking when backing up?
Haha! How would a sensor know? It's just a pickup not a Mars lander.I turned mine off when it slammed hard on the brakes while backing my boat in the driveway. I’m guessing when I was turning sharply it caught the side of the boat and thought it was a vehicle in the cross path. You would think with a trailer hooked up it would automatically know that and deactivate.
My point was is whenever trailer lights are hooked up the truck knows a trailer is connected. In this case it should be programmed to default the cross pass detection to the off position since it’s pretty much useless with a 25 foot trailer behind the truck.Haha! How would a sensor know? It's just a pickup not a Mars lander.![]()
If you are using the 4-way trailer connector, it doesn’t detect a trailer. Those are just light circuits, and the light circuits aren’t what determines if a trailer is attached. The brake feed on the 7-way trailer connector is what detects a trailer, because the brake feed on the trailer brake module senses a resistance. When a trailer is plugged into the 7-way connector, cross path detection is disabled, and the trailer length is detected.My point was is whenever trailer lights are hooked up the truck knows a trailer is connected. In this case it should be programmed to default the cross pass detection to the off position since it’s pretty much useless with a 25 foot trailer behind the truck.
Makes sense but still confused why my truck slammed on the brakes in reverse with a trailer hooked up?If you are using the 4-way trailer connector, it doesn’t detect a trailer. Those are just light circuits, and the light circuits aren’t what determines if a trailer is attached. The brake feed on the 7-way trailer connector is what detects a trailer, because the brake feed on the trailer brake module senses a resistance. When a trailer is plugged into the 7-way connector, cross path detection is disabled, and the trailer length is detected.
Correct, neither are active when a trailer with a brake feed is hooked up to the 7-way connector. You mentioned you were backing up a boat. Does the boat trailer use the 7-way connector, and does it have/use the electric brake feed via factory brake controller? Because boat trailers *usually* have surge brakes.Makes sense but still confused why my truck slammed on the brakes in reverse with a trailer hooked up?
Guessing it was my rear parking sensors causing this which also should default to off when a trailer is hooked up…..correct?
Seems neither should be active with a trailer connected.
Yes I am hooked up to the round 7 way connector. No trailer brakes since it’s only about 2000 lbs.Correct, neither are active when a trailer with a brake feed is hooked up to the 7-way connector. You mentioned you were backing up a boat. Does the boat trailer use the 7-way connector, and does it have/use the electric brake feed via factory brake controller? Because boat trailers *usually* have surge brakes.
There's the problem. No load on the brake feed so it doesn't "feel" the trailer.Yes I am hooked up to the round 7 way connector. No trailer brakes since it’s only about 2000 lbs.
So my question is how does my truck know that a trailer is hooked up to activate the Reverse Trailer Steering? Is that off the sensors in the rear tail lights? It calibrates the length of the trailer. You would think that would all communicate together.There's the problem. No load on the brake feed so it doesn't "feel" the trailer.
Trailer reverse steering is not associated with any of the trailer connectors or wiring. It uses the rear view camera to calibrate and function.So my question is how does my truck know that a trailer is hooked up to activate the Reverse Trailer Steering? Is that off the sensors in the rear tail lights? It calibrates the length of the trailer. You would think that would all communicate together.![]()
Got it. All starting to make sense now. By process of elimination I think I found the culprit. No load on the brake feed so doesn’t know a trailer is hooked up. Turn off rear braking and rear park sensors and should be good to go. Seems like a trailer should be easier to recognize. All these fancy electronics should be able to figure out anything hooked up to the hitch and deactivate redundant safety systems to suit.Trailer reverse steering is not associated with any of the trailer connectors or wiring. It uses the rear view camera to calibrate and function.
My truck shows a trailer connected indicator on the dash even when using a 4-pin on a small utility trailer. I had always thought it was detecting the trailer through the 4 pin plug. Are you saying the trailer is detected by the rear view camera?Trailer reverse steering is not associated with any of the trailer connectors or wiring. It uses the rear view camera to calibrate and function.
