I also use a cheap Amazon one, it's looks almost identical to the Chemical Guys one another guy in my local Ram Club has. Works great. I also use the CG Honeydew car wash in it. Mix 2-3 oz of the CG and the rest of the reservoir with warm water. Mix and spray. This was last weekend and took picture about 2 minutes after I finished spraying the foam.I believe they are all made by the same people. I went through two chemical guys ones and one Amazon one.
Currently my Amazon one has lasted the longest. And a fraction of the cost of the chemical guys version.
But the CG honeydew foam seems to work the best.
I’m not 100% convinced that it really helps (but I still do it).
You’re SUPPOSED to rinse after the foam cannon. This allegedly rinses off larger loose particles that would otherwise scratch your paint when you start wiping with the sponge.
If I'm doing a touchless wash, I like to do a pre-rinse with ONR before I hit it with the pressure washer.anything wrong with just pressure washing, then foam cannon with CarPro Reset then pressure wash off and dry with leaf blower? I dont want to touch the paint and I'll get it professionally detailed 1x a year by the people that did the ceramic coating.
I might try changing to a 1.1mm orifice. Honeydew has been awesome for me for years. Adam's mega foam had also been great. Might be another one to try.I havent had much luck with the CG Honeydew and my Amazon Foam Cannon, it does foam, but usually seems to be lowwer lather than I was hoping. Almost out so onto another brand to try.
Adjust the flow, and make sure you are diluting the CG soap properly in the reservoir. Helps to use warm water when mixing it. This is my cheap Amazon foam cannon and CG Honeydew after sitting for 3 minutes.I havent had much luck with the CG Honeydew and my Amazon Foam Cannon, it does foam, but usually seems to be lowwer lather than I was hoping. Almost out so onto another brand to try.
Thats about the consistency of mine after 30 seconds, Might give it another shot then..Adjust the flow, and make sure you are diluting the CG soap properly in the reservoir. Helps to use warm water when mixing it. This is my cheap Amazon foam cannon and CG Honeydew after sitting for 3 minutes.
I started doing this recently as well. Putting together a routine that I can maintain on the road, and have started spraying down with 16:1 ONR as the first step.i use rinse less wash heavily diluted as a pre wash
My Amazon foam cannon that hooks to pressure washer is awesome. Biggest thing is getting the mix ratio correct in the reservoir. And using warm water when diluting the soap for the foam cannon.I gave up on my amazon foam cannon and am now just using a pressure washer for pre-rinse and two bucket method.
I wet the truck 1st then foam cannon. After that, I spray that off without washing/touching the paint. Next, I wash with two bucket (this may be overkill because both buckets are pretty clean after I'm done). Finally. I come back with spray rinse off.Hi
Do you guys rinse the truck off after you use foam cannon or do you just go straight to the hand wash part with the bucket and rinse after.
