The magic box
Ive
Has anyone tried these. Curious if they work.
I’ve used a similar box from a company called MMB. It basically has the guts of an entry level android tablet. It interfaces through your USB ports and also allows for wireless Apple car play. I haven’t had any issues with it so far. It’s not the fastest thing in the world, but it will run Netflix, Hulu, etc.
I have this one, works excellent.
I have this one also but haven’t messed with it enough to give a review. What I can say is that Support was very responsive when I had an issue setting up the keyboard remote.
Yes, support is excellent. I had the first one (blue) for 10 month and it would not boot anymore. We had a video call and they walked me thru a firmware re install. We found out it was a hardware issue. They sent me a new one (red) newest model within 3 days.
Killed while driving and watching "I Love Lucy". We need more distracted drivers out there.
I don't use mine the way it was designed. I use it for ECU Data only.
I have the Magic Box and it seems to work so far
Just got this yesterday and it doesn't appear to be fully compatible with the 12" screen. Netflix is a no go, no pinch to zoom on Google maps. Android auto is unusable. Audio cuts out constantly. Wifi is trash with the truck Hotspot and my phone. One good thing about it is it made me appreciate uconnect more.
Sent from my SM-S908U1 using Tapatalk
What did you find out?
Did yours work? Netflix YouTube YouTube music, could you download from Google Play appstore? Screen mirror
I'm waiting On my 2023 Elite Limited 1500 loaded up rambox etc... In 2022 they switched the Giant screen to Uconnect 5 software
Couple of things here.
Pinch to zoom works fine on Google maps.
Your touchscreen isn't multi-touch, so it can't register to separate touches at the same time. That's a limitation of your hardware, not the device.
Netflix is the same way. The app itself doesn't know how to handle the portrait aspect ratio, you can simply use multi-app mode (if the device supports it) or make a homepage for the top half of the screen and Netflix will "fit right"
Wifi being a problem could be the hardware, or just the fact hotspots can suck depending on where you are.
Most of these devices can't download very many apps from the playstore. You can sideload the APKs but they come with a much older verison of Android generally.
I currently have a device that works with Hulu, Disney Plus, Netflix, and Youtube find. I could download other apps from the play store but not those. Torque and Alfaobd installed fine from the appstore for example.
I believe most of the boxes support screen mirroring, but why even bother. it's already running android, why bother wasting battery life on your phone to attempt to broadcast stuff that can just be displayed on the device itself. Also keep in mind there are 2-3 differnet protocols for screen mirroring that work to varrying degrees such as Miracast, and Chromecast to name 2. Compatibility is rough depending on the device and your phone.
With all that said. This device in question the Magic Box is grossly overpriced for what it appears to be offering wtih the current market.
You can get one of these devices from $150-300 currently. $390 is more then any I have seen and likely not worth it. The one I currently have I got for $160 on sale and works fine (despite having an older version of Android then listed)
Un par de cosas aquí.
Pellizcar para hacer zoom funciona bien en Google Maps.
Tu pantalla táctil no es multitáctil, por lo que no puede registrar toques separados a la vez. Esto es una limitación del hardware, no del dispositivo.
Netflix funciona igual. La aplicación no gestiona la relación de aspecto vertical; puedes usar el modo multiaplicación (si el dispositivo lo admite) o crear una página de inicio para la mitad superior de la pantalla y Netflix se ajustará perfectamente.
El problema del wifi podría deberse al hardware o simplemente al hecho de que los puntos de acceso pueden ser deficientes según dónde te encuentres.
La mayoría de estos dispositivos no permiten descargar muchas aplicaciones de Play Store. Puedes descargar los APK de forma local, pero generalmente vienen con una versión de Android mucho más antigua.
Actualmente tengo un dispositivo compatible con Hulu, Disney Plus, Netflix y YouTube. Pude descargar otras aplicaciones de Play Store, pero no estas. Por ejemplo, Torque y AlfaOBD se instalaron correctamente desde la App Store.
Creo que la mayoría de las cajas son compatibles con la duplicación de pantalla, pero ¿para qué molestarse? Ya funciona con Android, así que ¿para qué gastar batería en tu teléfono intentando transmitir contenido que solo se puede ver en el dispositivo? Ten en cuenta también que existen dos o tres protocolos diferentes para la duplicación de pantalla con distintos niveles de funcionamiento, como Miracast y Chromecast, por nombrar dos. La compatibilidad varía según el dispositivo y el teléfono.
Dicho esto, el dispositivo en cuestión, la Magic Box, tiene un precio excesivamente alto para lo que parece ofrecer en el mercado actual.
Actualmente, puedes conseguir uno de estos dispositivos por entre $150 y $300. $390 es más caro que cualquier otro que haya visto y probablemente no valga la pena. El que tengo actualmente lo conseguí por $160 en oferta y funciona perfectamente (a pesar de tener una versión de Android anterior a la que se anunciaba).
Disculpa puedes resumirme como lo vinculaste? primero debes tener enlazado el mobil al vehículo por vía Bluethooth? he tratado de configurar estas cajas pero el Uconeect interfiere la conexión y se anticipa sin dejar que la caja se conecte.
