GPS routing is terrible
scottmoyer
I have tried using voice navigation and the system clarifies back, "Did you say 123 Main Street, Abu Dhabi?" When I actually asked for navigation to something like Juanto Street, Altamonte Springs! I may be originally from NJ, but I grew up in the western side, so I don't have that NY accent. Oh well.
In general, car nav systems that don't use a Google map database are always horrible. BMW is one exception because it does not use a native routing system.
When I bought my 22 Big Horn with U-Connect 12 (I didn't order it), I was under the impression that system uses Tom-Tom for routing. Has the RAM Nav system changed since the introduction of the 5th generation truck? In other words, should I have an expectation that my truck will also be horrible?
Yes, the 22s with Uconnect 5 use TomTom, but it's still garbage with outdated maps compared to Waze or Google Maps.
I'm waiting for a nav system that tells me exactly how fast to drive, so I catch all the green lights.
Will never happen as most intersections are now in sensors that detect traffic, and are not just in timers.
Rlaf75
Takes potshots
I believe they use the same Tom Tom in the 22 uconnect5 system as they do in the 21 and older uconnect4 system. From reading on a couple of different forums it seems uconnect5 has it's own set of glitches different from uconnect4.
Ninety-9 SE-L
Tampa
That's true, but it actually causes an unintentional syncing up of the lights due to regular traffic clustering coming from other intersections. Many roadways, even major ones, are dead-empty most of the time, followed by dense clusters of traffic moving from light to light.
I have a 10-mile highway commute, but at each end, I have about 5-miles of local traffic and lights. I found that the lights are very predictable, even on zig-zag routes, because traffic patterns cause a 1:1 or 2:1 sync at other intersections. I tend to adjust my speed between certain lights because I know which ones are going to change and when. If I catch a red light, straight off the highway, I'll usually sync back into the same pattern as the day before.
Honestly, I just wish traffic lights were smarter and could track traffic better. It's very possible to manipulate traffic clusters in order to keep them moving in a group while also utilizing the dead space for cross streets to safely go. traffic light control clustering - Google Search
Im usually pretty good at timing lights, especially on my morninf commute as I travel before normal morning traffic. Problem comes from the random car that comes from a side street, usually turning right. They get to intersection, sensors sense cross traffic, while I am still just outside of the sensor range for my direction. Light starts to change, but since they are making a right hand turn, they don't wait for light. My light changes to red forcing me to stop when there isn't even cross traffic anymore.
