I wear mine but you can't dictate when or if your front seat passenger wears their seatbelt. I'm not listening to the seatbelt chime if they don't wear a seatbelt or don't put it on right away.Why does nobody want to wear the damn seat belt?
can alpha obd disable it? mine doesn't have a chime at all but not sure how it was disabled. the dash still says if driver or pass isn't buckled but it never chimes at all.
Clicking and un-clicking the belt for example at boat ramps, backing up to a trailer, or moving limbs/branches to minimize off-road pinstriping gets old quick. The chime is designed to make you crazy until you put on your seatbelt, unless you don't need the beltWhy does nobody want to wear the damn seat belt?
At least in my case, I always wear my seatbelt when traveling on public highways. However, my job has me bouncing around construction and ranch sites - I don't need a freakin' seatbelt when traveling 100 yards at 10 mph!Why does nobody want to wear the damn seat belt?
					donotpay.com
				I worded that last sentence poorly. I give my passengers ample time to put on their seatbelts, but some put it on after dicking around with other things they deem more important. None have ever not worn their seatbelt for more than a ~1/4 mile or so. Fortunately, I don't have to listen to the chime while they take their time getting buckled up.Although I don't know anyone who was ticketed for a passenger not wearing a seatbelt, many states can ticket both the unbuckled passenger and the buckled-up driver. The driver is responsible for making sure everyone in the vehicle is adhering to the laws.
Does the Driver Get a Ticket for a Passenger Not Wearing a Seatbelt?
What happens when you’re driving a friend that refuses to put a seatbelt on? Does the driver get a ticket for a passenger not wearing a seatbelt? Find out now!donotpay.com
Because it scares away the deer and pigs when I'm hunting. In the woods where I'm not going to use the belt. And, yes, it is legal to do not wear it on private property.Why does nobody want to wear the damn seat belt?
Thanks. I did follow that. Even getting the come at the end that should acknowledge. Trying again...Took me a few tries, but I was able to get it to work on my '21 lImited. Make sure when you turn the ignition to the on position, you push it twice. Otherwise you will be Acc, not On.
