Doors: Electro-Chromatic Driver Mirror Present, and Doors: Electro-Chromatic Passenger Mirror PresentIs there an Alfa obd setting for the exterior mirrors? We installed new mirrors with dimmable glass and can’t find if they need activation. Thanks
I had performance pages on my 8.4 for about a week and then radio must have updated while on a long trip. Screen displays indoor temperature and seat heat now on the top (didn’t before- only showed when adjusted temp). Perf pages are now missing. I still have them in the evic. I will try and reload them- every gauge worked and the hp/tq graphs were pretty cool. Also my off-road pages work fine in the evic- dropped off the 8.4 as well.
Be nice to figure out how to make them stay. I’m assuming the software update got mine.
Nope. A few things you can do with Tazer, but not with AlfaODB.A few things I’m looking for with alpha still, anyone know if we can do any of the following and if so what the settings are:
-enable surround cameras at any speed
-enable all uconnect menus when in motion
-disable active noise cancellation
-disable seatbelt unbuckled chime
-activate SurroundView and front camera when front parking sensors are triggered
-side mirror cameras on when blinkers are on
Also, does anyone know if there is a Jeep Wrangler alpha obd forum with the avail options for them? Looking to disable the seatbelt alarm in my wrangler too.
Thanks again for all your help everyone!!!!
You can just disable the seat belt chime yourself no alfa odb required. Get in and put your seat belt on. Turn to run and wait intil all the lights finish coming on. Unbuckle and rebuckle the seat belt 3 times then turn the truck off. Turn the truck on unbuckle and go drive to confirm you did it correctly.A few things I’m looking for with alpha still, anyone know if we can do any of the following and if so what the settings are:
Ive been looking for one and I can only find regular price.Ok thanks y’all
Someone sell me a cheap tazer!!!!!!!![]()
You can download the files as little, or as often as you like. Really no need to do it after every change. Have a stock file saved, and once you get all the changes made that you want, maybe save a modified file as well to be able to easily go back to it. Personally, I have never saved anything.Alfa setup:
Using on a Pixel 6 pro
Augocom FCA 12+8 adapter
OBDLink MX+
Is there an official help doc for alfa anywhere? Looking at the description of the app in the play store, they have:
This leads to page that doesn't respond. Googling around also leads to AlfaOBD, which also doesn't respond. I'm looking for some basic start up info like 'do these things before you make changes'. 'make sure you turn on this log to track changes', or in the configure car section there is a HINT that says to turn logging on to track changes...where do I do this? Is this the same as the upload to google drive feature?
Reading through these pages, I've seen other members talk about these settings, but I haven't been able to find details. Perhaps is buried in pages I haven't read? For example, I connected to my truck for the first time tonight and used the google drive feature to upload the "Body_Chrysler_info.log" file with no changes made. However each time I go back to the google drive section it asks me to sign back in. Is this normal? Since I uploaded to drive once, do I need to do this each time I make a change or if i make multiple changes can I do it at the end?
Appreciate the help!
I’m pretty sure yours is behind the instrument cluster. Ia that correct @Brutal_HO ?I have everything I need to get started and have read chunks and chunks of this thread. Does anyone have a picture of where the SGW module is on a 2022 power wagon? I appreciate the help! New wheels and tires will be going on Tuesday.
Thank you. I would prefer to go the KAOdTECH route because it is much easier to install but it has been out of stock on their website for the last week+. Anybody have a cable they don't need anymore?SGW is behind the cluster on HD trucks. Don't buy a Z-auto or similar bypass module, get a bypass cable for the HD trucks that plugs into the CAN IHS blocks behind the headlight switch.
KAOdTECH is the goto for cables but @Jimmy07 can also hook you up.
