We’ve all been there lol. First thing I thought yep he’s bored and just wants to tinker with something lol.
Traded my old 2019 Limited with 75,000+ miles in on a lightly used 2020 Limited Night Edition with under 17,000 miles last Friday. Since then ive installed my old Lomax Tonneau cover and carpet bed mat.
Also bought and installed a new hitch cover, took off the front plate mount and covered the holes with vinyl circles for now, not really sure i dig the bumper plugs as they stick out a bit too much and are noticeable. I probably need to get some better vinyl as the current vinyl just isnt overly shiny, cant tell from more than a couple feet away tho.
Contact Acogs91 on this forum. He sells the plugs painted with factory colors, they match perfectly
Shifts & Grins TRX tow hook adapter
Mopar TRX Tow hooks
Shifts & Grins Tow Hook Light pot bracket
Diode Dynamic SSC1 Pro light pod
Currently red backlight wired to running lights, not sure if I want to re-wire as brake lights or turn lights. I like how they slightly illuminate the tow hooks as they are. They only turn on when the lights are on.
Reverse lights come on automatically, but also have the option to turn on via aux switch as the positive is ran through a diode.
Coming home last night. Finally tested my single row / behind the grill light bar. This is ONLY the light bar being on. And phone camera was taken off of night mode.
That is a great light spread!. Which light bar did you use? I have a rough country 30" light bar on order.
It’s the RC 30in curved black series.
Light output isn’t bad. But the quality of the bar is crap like most things from RC. All the powder coating flaked off and had pretty bad corrosion from being on my other truck for only two years.
I sanded it all down, treated the corrosion, and repainted before putting it on this truck.
But it is just a $200 bar
That's good to know. I might put a good coat of paint before I mount it.
