They weren’t bad to change. All you gotta do is go through the inner fender liner. Couple screws and then pull the liner back enough to get your hand in ther to take out the old bulbs and then put in the new lights.
I just installed both the high and low beams. Everything functions exactly as expected - these lights are INCREDIBLY BRIGHT. From that perspective, problem solved.
The installation was incredibly painful. The idea that you just “reach up and change the bulb” is not at all true.
The amount of extra wiring and hardware requires that you completely compromise the dust caps (drill/dremel out a 1” hole) and just let these wires and aluminum components hang right out the back and get zip tied to whatever is near (with one hand by feel... I felt like an obstetrician).
Lights are dang bright but that install was a doozy.
