MurphBigHorn
- Jun 25, 2021
What code(s) are you getting for the CEL?Well, now my truck won’t start lol. Went from having zero issues for the 20k miles I’ve put on this to now all this from a weekend of a guy driving it
And have you lodged the issue with the uncle and the crash test dummy?
Oil pressure will keep engine from running. PCM will protect engine.P1524 - Oil Pressure Out of Range
Haven’t spoken to either yet
I am at a loss for words, people just don't care and have no respect for others.A customer of my uncle owns a construction company and was in the market for a new truck. My uncle told him I have a Ram, and told him I’d let him test drive it. Come to find out he told him he can have it for the weekend. I have other cars so I said whatever, let this guy I just met have it on Friday and didn’t hear back from him until today.
He called asking what the difference is between my truck and a different Ram with a couple thousand less miles for a lower price and then said his wife wants to try out a Silverado also. Told him I don’t want to sell my truck anymore and to just return it.
He just dropped it off at my uncles property, completely empty on gas and with a check engine light.
Edit: scanned the code, P1524, (Oil Pressure Out of Range)
Yeah that is not right, I will take a pic of mine later. 2 years of use and I still don't have any rubbing issues.The Long Door was rubbing the right(short door) when opening. Here are some pics. Does my MFT look normal? The third pic shows where the doors were hitting. It seems the long door is lower than the right door and that the left door doesn’t close all of the way judging by the last picture.
Jumped it and now it’s starting fine. Gonna leave it in my shop and have it looked at tomorrow
This is why have trust issues...I am known as the a$$hole in the family because I am so strict about leading my stuff out.
Or at lease a tank of gas... sheesh!!!Hope your uncle - the one who "volunteered" your truck for the weekend in the first place - will help with any repairs to damage that his customer caused.![]()
Your battery probably went Tango Uniform.Back to not starting, had to jump it again to get it in the shop to park it. Cameras also aren’t working now![]()
oh snap i was thinking at the hinges... i'll go out and look at mine right now and get some pics.The Long Door was rubbing the right(short door) when opening. Here are some pics. Does my MFT look normal? The third pic shows where the doors were hitting. It seems the long door is lower than the right door and that the left door doesn’t close all of the way judging by the last picture.
This is beyond something I'd be able to keep my sanity over. This clown had the balls to put a child seat in it?!?!?! and now you're having all these crazy problems? First, i would dis-uncle my uncle, or whatever that process is, but i'd DEF be on the phone to a lawyer to see if there is anything i could do about all of this... Where's Furio, Paully Walnuts and Christopher when you need em?!?!Well, now my truck won’t start lol. Went from having zero issues for the 20k miles I’ve put on this to now all this from a weekend of a guy driving it
Cameras will go out if battery is dead or disconnected. Takes a few hours of good battery for the system to reset and all functions to start working againBack to not starting, had to jump it again to get it in the shop to park it. Cameras also aren’t working now![]()
Thanks.oh snap i was thinking at the hinges... i'll go out and look at mine right now and get some pics.
Was there a couple years ago. Gets HOT!Yep. Nailed it on the weather too!
yeesh... soooo mine actually kinda does that too... which is kinda bad news i think because looking at it my long gate is a CH higher than my short gate... but i have never even noticed before i looked at this but there is a bit if rubbing of the metal at the middle where the latches are, but only slightly. that said there are an F-ton of bolts in the side frames that hold the "leafs" so maybe there is an adjustment to be made? be nice to hear from anyone who has a multi-gate from a previous model year thats a little older than ours... or even a lottle older preferably. Looking back at yours tho your contact is definitely closer than mine... sho hopefully there is an adjustment to be made.Thanks.
What do you guys think is the most likely recourse I can expect for repairs? I am sort of wanting to go for a completely new MFT tail gate since it was installed wrong and is now "damaged" due to FCA's error. I've done touch up paint for now and honestly it's fine if they fix the alignment issue, but I'm thinking I should expect more out of a $65K truck.
