I turned on the news for the weather and caught some of the other dribble about this and they said its only at approx. 2300 stations. I mean, it is possible they are wrong.Huh. Seems pretty common around here. But I don’t use it.
Maybe they meant full e85 not e15. There is only 1 place in my county with e85, luckily next door to work. Otherwise, I never would have tuned my mustang for e30 (mix of e85 and 93 pump gas).I turned on the news for the weather and caught some of the other dribble about this and they said its only at approx. 2300 stations. I mean, it is possible they are wrong.
That number truly surprises me. I figured a ton more places carried it. I never saw it banned in the summer either haha.It’s correct. It’s in the news now how the administration is trying to push more fuel stations to sell it since it’s cheaper.
Good reading here
Biden’s approval of E15 gas will only affect 1.5% of gas stations
Also never knew it was banned for summer use lol
Pure Ethanol is about 76,000BTU/gal*no mpg doesn’t suffer, I’ve been running it for a while now in my truck and other car. And my truck sits for weeks at a time in the winter, no issues. It runs better than 87 and is cheaper.
Actually, Ethanol burns cooler. It also burns cleaner....BUT....The main issue from running more ethanol is the heat generated is higher. If the engine isn't designed to handle it, then major issues can occur.
E10->E15 will drop your fuel economy because there is simply less bang per gallon. You need more throttle and more fuel to resist the same amount of wind drag.
Your performance will also drop, depending on how much your engine adjusts to the new blend.
Not performance, energy drops. In theory, it should take more fuel to achieve the same combustion. Might not be that noticeable for 10 to 15 % ethanol. When I went to e30 with my mustang, I lost 4-5mpg's.How many tanks of e88 have you ran?
Performance doesn’t drop, it’s still 88 octane. It pings less than 87 under load.
But by that logic running pure fuel should really bump up mpg numbers, right?
No, my mpg readings stayed relatively they same running pure fuel, 89, 87, and e88. Only thing that differed is how light my wallet was.
It does affect fuel economy, but it's likely that it won't be noticeable. We're talking about a difference in BTU's/gal of less than 2%. Ethanol provides approx. 30% lower mpg's than gasoline. So the difference will be less than 1 mpg, which is less than I see from one tank to the next. There are so many more variables involved with fuel economy that it would be difficult to notice the decrease you will have with e15. To say it doesn't affect fuel economy is inaccurate. It would be more accurate to say you probably won't notice the difference in fuel economy.How many tanks of e88 have you ran?
Not semantics, it's fact. But you're right about your anecdotal evidence that it doesn't appear to affect fuel mileage. Like I said, the difference is insignificant. No one will probably notice it.Now we’re just arguing semantics, A difference like that is so negligible you might as well say it doesn’t affect it. Remember we are talking about a 5% bump in e content. It’s insignificant.
I’ve yet to see some one post they are running e15 and their mpg dropped, all I’ve seen are people saying it’s stayed the same.
Kinda how saying adding a cat back doesn’t add performance. Sure it adds a very minimal amount. But it’s an amount no one will ever notice, thus it doesn’t add performance.
I'm in no way trying to talk you out of using it. Use whatever makes you happy. Thankfully we still have a choice of fuels we can use. I use ethanol free for all my yard equipment. I'd use that in my truck too if it wasn't 50 cents to a dollar per gallon more than regular where I live.I still hit my epa averages on my window sticker and I save around $15 every fill up and no engine pinging.
So I’ll keep using it.
Fair enough. My negativity towards it has less to do with the actual product, and more to do with the politics behind why it's being pushed out at this time.Just trying to clear up the stigma that many members on this forum have about it.
Almost Everyone who has a negative opinion about how it will hurt the truck and lower your mpg hasn’t used it.
There are no I’ll side affects, especially on a modern vehicle.
How many tanks of e88 have you ran through your hemi?
