Tazer dt lost sensors
bnh105
I changed the tire size and a couple small other things I did the full reboot and the two power cycles, I also unmarried , then remarried and did the full reboot again with two power cycles. For whatever reason I still have no front rear parking sensor available? Tire size is only 34.53 so under 35 which I know have people some issues. Any help would be greatly appreciated.
djevox
VP of Creative Thinking
MD
This may sound silly, but are the buttons below the infotainment for park sensors enabled?
Also, zauto is very responsive over email if you wanted to ask them.
bnh105
The light is on showing they are disabled , if i press to try and turn them on, my splash screen will say unavailable for front and rear
djevox
MD
I guess it’s possible that the tazer corrupted some data on the BCM. I wonder if unhooking the battery and leaving it overnight will give you a different result.
bnh105
That was my next step unhooking negative terminal for 20-30 minutes to let itself reset and see if that fixes it
bnh105
Tried this to no avail, zauto isn’t helping much at this point either so pretty disappointed with the Tazer dt right now
ramchaser
Won't work...If you go over 2558mm with alphaobd...It disables park sense with no ETA for a fix per engineering. Only fix is to buy the cable that installs behind the cluster currently.
Idahoktm
North Idaho
Not true. I used 2625mm's to reprogram my speedometer with AlfaOBD and my ParkSense still works.
bnh105
I’m using Tazer though, not sure what that equates to , but haven’t used alphaobd
MoreOvalteenPlz
Oklahoma
What Idahoktm said… I changed mine to 2672mm using AlfaOBD and my ParkSense works perfectly. Can’t speak for the Tazer or any number higher than than 2672mm though…
ramchaser
Absolutely will not work past what I stated on my Rebel with AlphaOBD or with the correct sales code when I use rebuild BCM reconfiguration with my WiTECH 2.
Idahoktm
North Idaho
Then you're doing it wrong.
ramchaser
Follow the steps in this video.
Same steps I followed the first time as the video and still have disabled park sense with any value higher than 2557mm however mine is a 19 but can't think that would make a difference.
HeliPilot
I adjusted my tire size via Tazer to 35.39", Parking sensors disabled (Unavailable), 2021 TRX
