Reverse tilt mirror(s)?
Steve76063
So, I just took delivery of my 2019 Delmonico Limited monday night (LOVE IT!), and in playing with it, I tried turning on the "Reverse Tilt Mirrors" feature. However, only the driver's side mirror tilts down...Is this correct, or should both mirrors tilt?
They should both tilt, at least mine do. I wish there was a setting to only tilt one of the mirrors, I like just having the passenger side tilt.
Both mine tilt also. I had the passenger side one get stuck in the titled down position once, I just moved it with the power mirror switch and it started working again. Haven't had an issue with them since then. I do wish there was a shortcut button to turn them on and off somewhere other than buried in the settings, because I don't like them tilting when I'm trying to back up a trailer.
Agree.
On prior Audis and BMWs I've owned, you could configure this to activate if the mirror adjustment selector knob was clicked to the passenger setting (and only tilt the passenger side which is what most of us use anyway). Very handy and quick to engage/disengage Really miss it.
Both should tilt.
My tilt mirrors have issues returning to the up position. We are going to try a computer reprogram to see if this resolves the problem. It is an intermittent problem and effects both mirrors
I have this same intermittent issue. Would like to know if you find resolution.
Is there a way to adjust the amount of tilt? Mine seems to tilt to far down?
Unfortunately, I don’t think so. Nothing in the manual to suggest you can do this.
Agreed. Tilts way too much.
I turned the tilt off its way too much
Both should tilt but having tried to adjust to it, I couldn't. It tilts too much and the Millie becomes unusable in my view. I turned the feature off.
Definitely tilt too much. I wish they had different levels. It has very limited usefulness.
Agreed, they tilt far too much for me. It seems they just power down to the lowest position for each mirror. It would be more functional if they powered a certain amount relative to where the driver has them set, therefore taking into account that anyone over 5'2" doesn't need them to point at the ground in order to see the back of the truck.
Between the convex corners and the 360° camera, there's no need to have my mirrors tilt. I do have the mirrors tilt down in reverse with the Corvette to make sure I don't curb a rim. I get tight to the curbs when parking it to give me as much room as I can on the other side of the car. They tilt way down, too.
When I check for it to tilt in the settings, it automatically uncheck itself within a few seconds and don't tilt at all. Am I the only one having this issue?
First I've heard of it. I'd bring it in for that. Or maybe do a reset on your uConnect settings first and then try again.
