NON-ORP 5100 Install This Weekend - Setting Advice!
Ibanez540r
So I've read every page of the "Bilstein 5100" thread, the Lifts/Level sticky, and a million other related threads. Still not 100% sure on what to do... I have a 2019 Laramie Black Appearance 6.4' bed with the 22's, just recently put on 305/45 Toyo Open Country AT 3's. They're essentially a 33x12" tire. I've seen very few pictures of NON-ORPs with a similar setup, they're either ORP or Rebel's or have 34"+ tires that change the dynamic.
I have the front and rear 5100s in my possession and the motofab 1" rear spring spacer. I'm between
Setting #5, rear stock height.
Setting #5, rear 1" spacer.
Setting #6, rear 1" spacer.
I wanted to go with a larger tire but did not want to go to an LT. I don't want to have too much tire to fender gap and make the tire look too small, but I also don't want it to be too subtle. I want to visually be level or a slight rake. I do not want the front to appear higher.
What say you? Anyone has similar, please share a pic.
Please provide your current measurements from ground to wheel well, front and rear …. That is where the whole decision making process starts …. I’ve been grinding on this decision since October
I meant to include them
Hub to flair:
Front 21.5"
Rear 23.75"
Ground measurements were:
Front between 36" & 36.25"
Rear between 38.5" & 38.625" (5/8)
THESE MEASUREMENTS WERE TAKEN BEFORE THE 305/45'S WERE INSTALLED. I need to take new ones with the tires.
I would say you are around 2" of rake, as the front fender-well is cut about 1/4" higher than the rear. So position 5 gives you 1.7" and if memory serves me right position 6 is 2.2". I would go with 5 and see what it looks like, then if you want more rake, add the 1" space in the rear. If you go with 6, I would say you will need the rear spacer or you will be slightly high in the front.
If you go with either setting 5 or 6 and the 1" spacer those 33's will look small in your truck.
I agree with ^^^ this …. At 1.7” #5 you wouldn’t have to mess with UCA’s
I disagree …. Some people like the “stuffed” look, some like a more “lifted” look with a good bit of fender gap
Diou read the OPs initial post? He specifically said he does not want too much fender to tire gap
Sure did …. He also says he doesn’t want it “too subtle” ….. so as you can see, not sure “we” can tell “him” what he wants …. Lol …. As is the case in so many threads
Put the front to the stock setting clip if that’s the case. This was stock with 33s. Non orp
Guess it depends on how you interpret his comment. Just a front level makes a very noticeable difference, so there's really nothing subtle about it. I have 34's on my ORP truck with front Bilstiens set at 4, and will probably go with 35s the next time I buy tires.
Thanks guys. I know it's difficult to articulate or interpret subjective opinion. I think I'm going to go with my original gut thought, as 397Stroker suggested, at setting #5 and see what it looks like, then add the spacer if needed.
I guess I was thrown off by seeing a few at #6 with 1" spacers that looked great, but I'm pretty sure they had 34" tires.
ferrai0l01 - I'm surprised that's at stock height as it appears to have a decent stance. My truck visually has much more rake.
Well the front is stock. Rear is lowered 2in there.
Imo I wouldn’t ad any lift to these trucks if only running a 33.
Heck I’m running basically a 33 now on a 2/4in drop
