Spent about 7 hrs popping in the VICE hidden winch. Pretty straightforward install when watching their YouTube videos.
Looks good...that's probably my next upgrade
Oddly enough, other than the alignment I got after my leveling kit was installed, I've never had an alignment done on any vehicle I've owned.
I got the truck with 32k miles, and both front tires had significant wear on the outer edge- it wouldn’t have passed state inspection I just bought new-ish tires on FB, so figured it was a good time to get it done. The front passenger side was off but only a little, so most likely the previous owner just never rotated. I rotate the tires on all my vehicles when I change the oil. It’s probably overkill but at least I know they’ll wear evenly.
Just some of the things to worry about when buying a used vehicle.
I added the missing ambient lighting above the upper glove box and to the sides of the instrument cluster to my truck. I give this mod 1 out 5 RAM horns. Not worth it. Actually looks better in pictures than in person.
Popped the cold air intake into the truck. Hardest part was being 5’5” and trying to work under the hood hahaha check out my step stool! Deciding if I want to put the K&N stickers on or not.
I'm 5'10" and can't reach the oil cap :ROFLMAO: I use a work platform myself ;)
I mean it's a nice touch and looks good, but THIS is ambient lighting!
(obviously, I don't drive with it like this, I keep it on a faint red)
That would make me sick lol
Yeah THAT is distracting, hahaha I don't need a rave going on at my feet while i'm driving.
. Had to show off its capabilities. It's got a ton of modes and brightness levels. I keep it solid and on level 2 of 10 brightness. I can't imagine, besides a car show/meet, why you'd ever want all that nonsense.
Converted my OEM LED tail lights into Night Edition replicas using VHT Nightshades. Taping them off was a PITA but it was well worth it. Zero issues with the blind spot monitoring system or cross-path detection. Pretty happy with the results, especially for the price (~$40).
Products used :
Did you follow the thread on here about installing that? How was shipping time for the parts you needed?
First oil change at 2038 miles. Next one will be at 5000 then every 6000. They rotated the tires. I did not request that so they took the 20 dollar charge off
Had the oil changed, tires rotated and re-balanced, and washed it. I also installed the Dongar USB adapter behind the rearview mirror. This way my trailer TPMS monitor will always be plugged in and charged without a cable hanging down to the dash.
What kind did you use? Been thinking about adding these as well
FYI - some reading material
Guess I bought another new tire for it.. Not like i just bought these tires on tuesday or anything.. :mad:
EDIT: Also, if someone could figure out how a razor blade gets turned up like that and sticks into my tire, let me know. Because it feels like someone propped it under there in my driveway or something. I'm the third truck in a few weeks to get a flat on my street.
