Finally got the front hitch mounted and removed the tow hooks. Picked up some plugs for the 2 lower license plate holes. Test fit the plow and I’m in business for the next storm.
Gotta do a resonator delete next and install CAI.
Put in my tinted tail lights and opt7 light bar under the tailgate, ground force bed cover(which I don’t like), Got a 3/2 lift going on and some 22x12’s coming in a week or two. Got a set of night edition headlights I gotta get put on also.
Washed it then tested some new paint correction pads and compound on a small corner of the bed .... which led to me paint correcting the entire truck.
Before
After
I micro cut pass with polishing compound and 2 polish passes with micro cut pad then finesse polish pad and an IPA wipe between each step and at the end
Added sound deadening material to the doors on Friday. Now that was a royal PITA. Didnt do a very good job rolling it out, so when I lowered the front drivers side window, adhesive was sticking to it and leaving tracks, had to take that panel back off and stick it down better.
But…on a much more positive note - my lift and coil overs were delivered; so most likely will be having that installed before the end of the week.
Installed ARE Z2, waited 3 1/2 months for this thing
That's a slick looking topper! Are you happy with the fit? I was actually leaning toward that model, but the local ARE dealer treated me like trash, so I drove 3 hours to get a Leer. Customer service is a real thing that amazingly a lot of business owners don't understand.
Washed it then took the wifey out shopping.
Side note, I'm really loving the Adam's Waterless Wash!
That's a pretty truck. Hope you're getting tires soon though!
Sent from my SM-G991U using Tapatalk
Reminds me, I also rotated my wheels this weekend. My back tires were significantly more worn out than my fronts were.
I got new wheels a little over a year ago and I had told them to rotate my tires as they swapped wheels... well they didn't 🤦‍♂️ and I just noticed about 2 weeks ago. Fail on my part too.
Just got my front camera hooked up and used AlfaOBD for the first time to activate it. The soft key hasn't shown up yet, so I don't know if it even worked or not. *crosses fingers*
  • Back
