Aftermarket Upgraded Reverse Lights
31RamIt
Anyone have a reverse light solution? Seems like the reverse lights are pretty meh on my pickup. Looking for some more brightness. Looked at the under tailgate lights, but I don't want the brake and turn signals. Just bright reverse lights.
Best of luck with your reverse lights.
We at Dark Dune are about to release a reverse light bracket setup in the next few weeks that will fit all 5th Gen RAMs. The brackets can fit 2×6inch light bars. They are geared towards the offroading style so a quite heavy duty with multiple anchor points. Direct bolt on fitment, laser cut and powder coated. You can view them in more detail here; https://www.dark-dune.com/collections/ram/products/ram-1500-reverse-light-brackets
Will they work with the MFT and the center step?
So $195 for just the brackets and still have to buy the lights?
Did you just wire it into the trailer plug?
Yep, very simple. Her is how I mounted mine.
I also have a Court adapter ready with plugs, just need to wire the light to them. If you want it, let me know.
I have the VLEDs licence plate frame and its bright as hell. Though i do like the in the sensor trim option that's listed above too.
I was just about to order some sort of lights to increase the reverse lighting last night and I didn't get a chance before I left work. When I got home I was fiddling with the cargo lamp button and realized that it will turn on the lights in reverse and it made a huge difference in lighting. I don't think I am even going to bother installing lights now. I do not have the led cargo light. I will note that I also have the trailer mirrors with the lights in them as well and maybe they also helped, but it lit everything up nicely. I'll try and get pictures next time I drive in the dark (if I remember).
How did you mount them so they stay in the holes?
I was wondering the same, no screws in sight so imagine silicone/epoxy or VHB double sided tape.
We are releasing some back up light options for people running our rear tow hook brackets and for the TRX (they mount to the rear tow hooks). At the request of a customer on here, we are also working on some other options for people not running rear tow hooks. Keep an eye on our vendor page on here to see them when they drop. Thank you all for the support. This forum has been great!
99E578EF-54A0-4EAB-9DE0-009DC2BFFEE6.JPGIMG_0454.jpg1ACBDA2A-851C-4B67-A35A-46BA974CD2E5.JPGIMG_0482.PNGIMG_20220308_100230_01.JPG
