Gas Tank Size - Is it Accurate?
SpeedyV
Ram Connoisseur
Fort Worth, Texas
I'm having issues looking it up. Says 'contact administrator'.
It would be cool to be able to get even another 30 miles out of a tank. Would make my trips to the cabin and hunting grounds without a fuel stop. I'm always so close to home when that "Low" comes on. And it's usually 23 gallons to fill it. I just assumed..
If it’s 23 gallons to fill it, and your truck was running when you pulled in, then you know it’s a 26!
JoeCo
NY
Are you entering it with all caps and no spaces?
Drivinfast247
Yes I am. I have the window sticker but it doesn't appear to list capacities.
Here is my VIN 1C6SRFMT4KN917932
Drivinfast247
You don’t have eTorque.
So you have the 26 gallon tank
Yes, I do not have eTorque. Thanks for the clarification of tank size.
I will test actual DTE in the next month or so when I head to the cabin. I'll bring a 5gal can in the bed just in case.
bikesnbeer79
Are you saying that all NON-Etorque trucks have 26 gallon tanks? I'm looking at the window sticker right now of my '21 big horn NON-etorque, and it shows having a 33 gallon tank.
SnowBlaZR2
Fuel Economy Champion
FL
No, he's saying that 26 gallons is the standard tank size if you don't have eTorque. You can upgrade to 33 gallons, eTorque or not.
Drivinfast247
23 is eTorque
26 is non-eTorque
33 is optional
I just learned that.
JoeCo
NY
Just checked and my 21 will come up but a previous ram I had isn't currently. May be a server issue or something like that on their end.
