MishMashRAM1500
- May 4, 2021
I brought this up recently, buried within another thread I started about headlight options in general (https://5thgenrams.com/community/th...r-preference-and-would-you-do-it-again.36595/), but due to my ongoing experience, I thought it would be worthy to call this out separately to help others avoid the risk of a headache.
I know some of you on here have the headlights, and for all intents and purposes are very happy with them and have not had any issues (like @JBowman ) . I am happy for you. Truly, and I hope you never have an issue with them...which will be the point of my thread.
I know of at least another on here that has had the same experience I have, and ill leave it to him to post up.
Not VLAND, and not for me nor others i've found.
The issue: Faulty left headlight turnsignal (which I summise is actually the LED board itself):
You can see from the video without ANY intrusion or interference...it goes from working to not. All connections are secure, and the issue occurs only after it is warm. I have securely checked all connections etc. I know it is installed correctly as I have no issues with the right assembly which was installed the same way.
Here is a link to the exchanges I have had with them, beginning with me first notifying them on January 19th 2022 of an issue with my turnsignal in my headlight, which was within a week or two of installation: https://docs.google.com/document/d/1eMLdou2kj08WRSrAwW_XeJr_ozoIcPpM6pfsXDr5pb0/edit
(Make sure to ZOOM to 200% to read it)
Short of reading that, it is now Feb 25th (more than 30+ days) and no closer to any sort of resolution. I have asked now most recently that they just refund me. They will not reply to that. If you look at the exchanges, it looks to be an attempt at this point just to keep delaying me, hoping I will give up. They have blamed me for the issue with the turnsignal, suggesting a bad installation and anything having to do with that end of things. I have complied with every single request...sending videos, pictures and more.
Again, I realize there are folks on here like @JBowman and others that have no issues with their lights. I recognize that and that is not my point. My point is if you roll your dice and buy this headlight......then have an issue...you could be screwed.
I did more research and realized that I was not alone, and not only to RAM.
Spend wisely
- My point of this thread will be that you are seriously just taking a chance with your $600 if you choose VLAND.
Spend wisely
