Do you know what your measurements our compare to PaHydroRam's, sense they are similar ? Trying to figure out which way to go.
My truck has a bit more rake than PaHydroRam's has. Mine is @ 41" front and 42 1/4 rear.
Anyone have pictures of 20x10 -12 on 33s with or without a level? Finally getting the size narrowed down. Thank you!
It didn't rub at all until I installed the Husky mud guards. It would rub on the inside of the guard when I was backing up, full lock. I trimmed the guards on the inside a little and it doesn't rub any more.
Appreciate it, thanks again!
'22 Backcountry before and after a Belltech strut level. I set the Belltech to 1.5" which resulted in raising the front 2". I still have 1/2" of rake. Still undecided about changing upper control arms. l also removed the active and stationary air dam so I can mount my plow.
View attachment 119067View attachment 119068
Woohoo...us back country folks have that 1" to play with factory.
I'm going to try a different route this time. So as you know they come with 32.1" tires. I'm going to upgrade to basically the same size tire, but in a 20" setup. (275-65R20) on fuel rims that I ordered for my first ram...lol
When I measured, it should give me an extra 1-1.5 inches height. I'm hopeful to avoid getting shock upgrades because I dod that with my old 2012 (bilstein 5100 set to 2.1", then in 2020 I got rc strut leveling kit).
2016 Dodge Charger scat pack
Just got my 2019.
added:
Motofab 2” level
LT275/65/20 Bridgestone AT revo3
Fuel Clash 20x9
almost there. Would like to switch up a little. I think it needs just a little more poke.View attachment 119579View attachment 119580View attachment 119581
Looks great, congrats!!
Really looking forward to seeing how you like those Revos.
Any initial impressions on the snow and ice it looks like you’re dealing with?
The lack of the 3pmsf rating is all that’s holding me back. Not on snow per se but ice… curious whether the tread compound turns to stone?
Thank you! I do really like the set up. If I’d do it again I’d roll the 20x10 wheels. Get that more aggressive stance.
But the revos have been great so far. Really happy with performance so far this winter. I live in North Dakota and we’ve had a lot of freezing rain lately. I did have them once before back in 2014. These new Revo 3 seem better on snow and ice than I remember my last set being. The look is improved too, I’d like a little more aggressive side wall tread though. However they are very quiet which is a plus. And they are a bit lighter than some of the other options I looked at. Hoping that helps to not kill mileage when jumping into an LT tire.
Thanks @Mattvb!!
The lightness was what drew me into the Revos, the acclaim is what will make me pull the trigger.
If they’ve been good for freezing rain in ND they’ll be great for Colorado winters!
Thanks @Mattvb!!
For sure! I’m sure you’ll like them. My local tire shop has a great satisfaction policy. So I’d just check with a shop like that. I can run then a few weeks and exchange if I didn’t like them.
I had the ReadyLift 3.5 SST kit installed back in December without the preload spacer and used the RL top hat spacer with the 5100 adjustable on #5 in the front and had the 5100 (non-adjustable) installed in the rear. I have a pretty noticeable rake compared to others on this thread. When measuring the rear from the ground to the center of the wheel well with 22" wheels it measures 42.75" and the front measures 40.25". Why could that be? Did the installer not do something right with the front suspension install? I do not have the offroad springs.
I put the 2" readylift leveling kit on my 2022 Ram 1500. But decided I want the 3.5" . My understanding is the A-arm is the same in both kits. But they wont
sell just the 3.5" spacers. Can I just use any spacers. Recommendations?
Just got my 2019.
added:
Motofab 2” level
Fuel Clash 20x9
Why do these look bigger than a 275/65? I have my lift combo of Fox 2.0 front coils and Icon 1.5” rear springs stuck in transit. I haven’t ordered the tires yet and I keep going back and forth on a 285/65 or a 276/65 on the stock 20” rims. Big Horn with the night package.
RC 3.5” loaded struts front. 2” motofab rear spacers. 275/65/20 toyo open country III. Fuel maverick 20x9. In its natural habitat
View attachment 121161View attachment 121162
Love the setup. I have same tire size but no lift. Did you replace the Uca with the lift?
A friend of mine and myself are going back and forth with the RC upper controller arm compared to the BDS uppers. They price out the same but Bds comets without the shocks.
I’m just interested in long term, instead of looks. We both do some mild off-roading in our trucks, so it has to be strong and last.
2022 Ram 1500 Back Country
2021 Jeep Wrangler Unlimited Sahara (wife)
