Dookie
You don't open the V4PR file and extract the files within it, you just drag and drop the V4PR folder to the USB. Start the truck, go to Medias, plug in your USB, and follow the on-screen prompts. Takes about 35 min. to upload.
Mine didn't look like this.... Maybe that is why I had several issues during the update!
I know you said above, so maybe go back and make sure the VehConfig 1-Performance Pages Present = YES is applied, others said it came up after an overnight sit versus with the 2 hard ECU resets like I was able to do.AlfaOBD was also being finicky this afternoon. It dropped Bluetooth connection a few times while trying to make the changes and it even told me that one of the options weren’t supported on my vehicle. I restarted my tablet and the app and it seemed to do the trick. I finally got everything changed over and squared away. It’s Just one of those days I guess lol. I am unable to force reset the ECU with my setup so I’m going to give it the night to do whatever it needs to do so that it will show up on the Uconnect.
Yeah, I'm going to check again in a few hours. If it still hasn't shown up by then I'll double check the settings to make sure everything applied and saved properly. I'm starting to see the added value from the MX+ now though. I might have to look into grabbing one of those eventually. I didn't realize the cheaper OBD interface options were limited from connecting to certain modules such as the radio option like Jimmy explained.I know you said above, so maybe go back and make sure the VehConfig 1-Performance Pages Present = YES is applied, others said it came up after an overnight sit versus with the 2 hard ECU resets like I was able to do.
USB has to be less then 32GB and formatted FAT32. 16GB is best.So I tried to update my radio using the pr39 and all it kept saying was media not found. The USB drive would light up 3 or 4 times and nothing more. I extracted all files on the v4pr folder to the USB. And nothing worked, I have 2019 rebel with 12" screen. Can anyone point me on the right direction I think I'm doing the steps correctly
Updating the software and enabling using AlfaODB. It's all listed in the posts above.Everyone is getting these pages just updating the software??.. or updating the software AND the use of AlfaOBD?..
I have the same question. Wondering if this is out there for us "smaller" guys.Do you know if the performance and off-road pages are available for the 8.4" screen?
Don't extract all the files to the USB Drive. There should be only the folder "VP4R_Update" on the drive.
Your USB should look like this.
thanks to all of you, for the help. so figured out that having the NR28 in order to update it to the PR39 i needed to update to the LR34 first.
My 2020 doesn't have the off-road page in the guages evic. Can't help yaI noticed that on the gauge cluster, there is now a blank screen on the #4 setting (one click below the off-road setting on my menu). Anyone know what this should be and if we can somehow enable it?
