 - Feb 24, 2018
- Solutions
 - 1
- Location
 - Central Pennsylvania
Skip the 6.4 and go with the 6.2 SRT Hellcat. Better engine, and it’s already in a Ram 1500!I just watched this, that Wagoneer is bad ***! I wish Ram would have put the 6.4 in the 1500 as an option. Doubt it will ever happen now, probably going the 6er TT route.
They sell way too many 1500 RAMs to risk putting a 6.4L in there, it would seriously dent their CAFE numbers. They just recently stopped buying carbon credits from Tesla, adding a 6.4L in a 1500 is a no-go. Of course unless they make it a high-cost option like the 394 in the Wrangler to keep numbers down, however that would put a regular 1500 really close to the MSRP of a TRX.
I just hope we still have a V8 option in the future, since the I6 Turbo is pretty much confirmed. But considering that Ford and GM still offer V8s and RAM is known as the "Hemi" truck, I think it will still be offered as an option.
Pretty sure that CAFE numbers are calculated using MPG. If that's the case, Ram is hurting themselves by not offering the 6.4, in the video above the 6.4 crushes the 5.7 in every metric. It's faster, and gets better MPG, all while being in a heavier truck than the Ram.
This video pretty much confirms my suspicion and what I've been saying all along; the 6.4 (SRT) would be the best engine for the this truck and would destroy the competition.
My bad, I didn't watch the video, I assumed the 6.4L in the RAM would get even worse mpg than it does now. If it's somehow better mpg and performance if it was put in a RAM 1500, than I'm all for that.
When I hear the HC motor in the TRX is averaging about 10 mpg, considering it's massive power advantage over the 5.7L in a heavier platform, I does make me wonder since I'm barely getting over 13 mpg in my truck. So yeah, that does make sense.
It got 24 mpg unloaded, their bighorn got 21 on same test. Not EPA ratings, actual "at the pump" calculations!
The 6.4 also got better mpg towing, just by a fraction of an mpg but at least its not worse, and of course towing performance is much stronger (13 seconds 0 to 60 instead of 16 IIRC).
That's impressive, the 6.4 is the SRT version as well? I was assuming the truck version like on the Powerwagon.
Yes the SRT. The BGE is a different beast designed for durability; peak power numbers are only slightly higher vs the 5.7, but no doubt it still feels stronger due to better power lower down as well.
I'm not all that shocked considering many GM 6.2 owners say their MPG is equivalent to the 5.3.
I think the price will make it unlikely to get in the RAM 1500, I mean if you compare the Wagoneer vs Grand Wagoneer, that is $69K vs 88K base MSRP for a 5.7L vs. 6.4L on the cheapest base price.
You will likely approach TRX territory with a 6.4L equipped RAM in terms of pricing. Which is something they do with the rather limited 394 Wrangler. It could be done in the 1500 class RAM, but not in any volume.
Yep. But you need to run premium in the larger engines. And in some states it’s $1 or more per gallon. Which really adds up quick.
There is much more difference than just the engine as you go up to the Grand Wagoneer. I don't see why the 6.4 would have to cost more than $2000 over the 5.7 in a ram if all else is the same.
Absolutely, but there are no 6.4L SRT motors in any FCA product that is in any volume product, especially on the truck/SUV side of things. The Wrangler 392 and Grand Wagoner are it at the moment, and they are priced at $75K Wrangler and $88K GW at the lowest base prices for each.
I just don't see how RAM is going to put an SRT version of the 6.4L in any product for only $2K over a 5.7L. They are positioning it as a special engine with pricing to match. I can see it in a TRX Light, something with less power at a lower price point.
