OK, I thought it was 2" but now I cannot find any reference to that height. Not sure where I got the 2" from.Off-road group is only 1" over the non-offroad group suspension.
42psi they put inDid you check your pressure?…. They could have put them at the max psi from the sidewall
The Rebel sits about 1.5-2" taller, but part of that is the stock 33" tires, vs the 32" tires on the Off Road group. The suspension itself only adds 1".OK, I thought it was 2" but now I cannot find any reference to that height. Not sure where I got the 2" from.
It sure seems like 2" higher - I had to get the side step to be able to get in without strain whereas stock ride height was easy to get into, and 1" wouldn't seem to make that much difference.
If there is a definitive statement from Ram that it is just 1" I will accept that and will stand corrected.
Dave
tfltruck.com
You can get 33" Nitto tires with an XL rating.If this is your first run with E rated tires, it will take some getting used to. Give it about 4,000 miles and it'll feel better. Not sure if that's just from getting used to it, or if they soften up, but that's been my experience. Either way, if you want to be above a ~31" tire you don't have a choice but to run E rated tires.
Thank u for input. I’m in to deep (to much money invested tires, lift,install). Either way I will have to get used to itIf this is your first run with E rated tires, it will take some getting used to. Give it about 4,000 miles and it'll feel better. Not sure if that's just from getting used to it, or if they soften up, but that's been my experience. Either way, if you want to be above a ~31" tire you don't have a choice but to run E rated tires.
Brands and sizes most definitely matter. There is no one size fits all air pressure that works for every tireI had 10 ply E rated Ko2 tires on my Silverado 4X4 1/2 ton pickup. I ran them at 35-40 psi with no ill effects. Maybe tires brands matter?
Do you guys think if I put 1750 miles on truck and the Springs where compressed an extra 2 inches that I ruined new fox shocks and stock front springs are ruined?
Maybe? But doubt it. Have the dealer switch it out to the way it is supposed to be. If ride is still somewhat ****ty, I’d throw a fit with service manage and get them to order and install another new kit the way it should be.
Side note……..most of not all fox suspension parts are fully rebuildable through fox directly.
