Pulsar on a 2020+
Yeah I called Edge and was on the phone for about 30 mins and they weren't no help. I went ahead and ordered their model of the pedal commander. And I'm going to try it out.
I went ahead and ordered the Edge Amp'd throttle booster(same as the pedal commander). They said they haven't had an issue with them working together on their testing. So now I got a pedal commander for sale lol
Ok so I am running the Pulsar and the Edge Amp'd throttle booster. Have been for about a week now and the truck is throwing the same codes as previously. Today I pulled the throttle booster and and will run with just just the Pulsar. And see where the problem lies. I'm not sure if my computer PCM was reflashed when I took in for a warranty repair back in Nov for the steering wheel. But I had drove it just fine with combinations no issues until then.
Does the pulsar offer any throttle adjustment or are you best running both items?
You’re probably best running both items, the pulsar adjusts throttle sensitivity in each drive mode: Performance has higher throttle sensitivity and it goes down in eco.
Pulsar only adjust a little. But I am currently running into issues having both on after running them for about 8-9 months of having the truck. I'm contacting Edge tomorrow. Pedal Commander has said it shouldnt be an issue. I think they have put an update put out and updated software in the truck. And the something either the Pulsar or the pedal commander don't like it. I also purchased the Edge Amp'd throttle booster and the same issue. Which leads me to the truck.
I just bought a Pulsar. I have not taken it out of the box yet. Do I need to have that update cable? How do I know if there's an update? I have to buy the cable, install the software, just to see if I need an update for a brand new product? You'd think they would include it for the price of this thing.
If it's brand new from Edge, it should have latest update on it, unless there is something new within last 2-3 months. And even so, it will still work on your truck without it.
Anyone have any issues with parking sensors not working after programing tire size? Tia. 2021 limited 5.7 ET
WHATCHA ASKING FOR IT? P/N? IS IT THE UPDATED VERSION... HOW LONG DID YOU USE IT, WHY ARE YOU SELLING?
I like mine. No problems. Works great. I have the newer version. All updated.
Installed mine about a month ago and love it, my only issue is the sensors not working due to my 35’s. Spoke to edge about it and apparently they’re working on a fix for that, so hopefully soon.
Make sure the speedo is actually correct compared to GPS. I set mine for the sidewall size, but speedo was off by 2-3mph. Had to drop from 275/65/20 to a 275/60/20 to get speedo correct. That might help you out to get tire size setting to something that will allow sensors to work
