I know there was talk about this in the past but now I've read a couple of things that have me second guessing. Does the ORP have the "Off Road 2" setting? Mine wont go to that, it just has Entry/Exit, Aero, Normal, and Off Road.
As stated above , though with more detail:
Normal ram. ORP
OR2. OR2
OR1. Normal
Normal. Aero
Aero. N/A
Entry. Entry
What's the max speed on ORP OR1 before it forces a drop?
Edwards, I think it all depends on how you look at it.
I've looked at it as this thread (which you participated in) https://5thgenrams.com/community/threads/off-road-air-suspension-heights.351/page-2
states - namely the OR2 is the same for both, OR1 for a standard truck is "normal" mode for the offload package (hence the 1" difference), Aero is the next step down (and yes, it is apparently 3/4" difference vs the 1" that would equate to "normal" in a standard package truck), and the exit / entry height is in theory the same.
I understand you can view the ORP trucks as only having "OR mode", but really it is the same height as "OR2" in other trucks, so this may just confuse folks.
Personally I wish they'd kept all the levels available, even if the "default" around town mode was OR1. I do wonder if they tweaked the driveline angles or anything (otherwise why not make Aero the same and improve mileage?).
Not trying to be confrontational, just pointing out there is a different also-logical way of looking at it that may be easier for folks to compare the relative truck heights. I fully admit there may be other threads with more information, but that is the one I found and recalled from reading lots of posts while waiting for my truck along with the rest of you![]()
The only way to know for sure would be to check the part numbers and I believe I read they are different.So is ORP just software coding on air ride trucks? What’s to keep someone from programming a non ORP truck to the ORP height settings?
What does ORP stand for?
OffRoad Package. Also called ORG by some. OffRoad GroupWhat does ORP stand for?
