Start of 2022 Production.
Same reason the individual airbags, ABS, and most of them items that are on that list I posted aren’t included on your POC? What is that reason? Ram being lazy? A more detailed list of every part on the truck is not available to the serfs? I don’t know. Re-read the list I posted and it seems to be all standard stuff now. When bought my 2014 Jeep Grand Cherokee Turbo Diesel BSM was a standard safety feature. But really, I don’t have an answer for you. Only Conjecture
I do see it is standard on the limited on the Ram build site. Thanks
I see it is standard on the limited, but not on the longhorns. BSM is showing however on my POC on 07/08. But I can’t seem to show BSM on a new build on a longhorn on the Ram build site. Are the longhorns being build have it?
If you go in ram trucks you can search ‘22 inventory and the summary of each truck is very detailed unlike when you use the configuration. You should be able to see if it is included in the trim and options you search.
Just did a search of all my build sheets. 9,331 Limiteds total, and 9,331 Limiteds with Blind Spot and Cross Path Detection.
I do see BSM is standard on the limited. BSM is on my POC on my 07/08 longhorn order, but I can’t seem to build a longhorn on the Ram site that has BSM ( not standard and cant get it with a package ). Are the longhorns currently getting built have the BSM?
Ram website is not up to date. I use the Costco auto program website which seems accurate.
Here are the totals for all trucks built to date with BSM
SeriesBSMTotal%
Limited
9722​
9722​
100.00%
TRX
3474​
4334​
80.16%
Longhorn
2113​
3881​
54.44%
Rebel
683​
8549​
7.99%
Laramie
885​
19143​
4.62%
Tradesman
32​
715​
4.48%
Big Horn / Lonestar
642​
34514​
1.86%
Sport
29​
5437​
0.53%
FWIW, on my 2022 Laramie order they changed the name of the Level A package to Level 1. Package price went up, but it lists BSM as being part of the package. Printout from my dealer...
Yea I can select Level 1 on that site but not the Ram builder.
Thanks so much
SeriesBSMTotal%
Limited
9722​
9722​
100.00%
TRX
3474​
4334​
80.16%
Longhorn
2113​
3881​
54.44%
Rebel
683​
8549​
7.99%
Laramie
885​
19143​
4.62%
Tradesman
32​
715​
4.48%
Big Horn / Lonestar
642​
34514​
1.86%
Sport
29​
5437​
0.53%
THIS is probably why I have been “gathering parts” for 108 days.
I sure hope not! Just assuming. We'll see I guess
I will worked at a Chrysler plant before the Democrats shut it down. (Built the transfer cases) we always had the week after Christmas off and the higher sonority guys came in for double time to keep the line moving. I wouldn’t say any difference in quality. Everything is automated to the point if you don’t do your job correct, the cameras /sensors won’t let you send it down line.
