Quint
I finally installed tow hooks in my 2021 Big Horn, since Chrysler was too cheap to do it at the factory. When watching the install video (and in doing the work), I learned about these motorized air dams that all 5th Gen trucks have (unless you have air suspension) that activate above 35mph for better aerodynamics. I also was not aware that we had motorized shutters in the front grills. Here is an article that I found about them:
www.repairerdrivennews.com
I never knew that our trucks had these standard. Was I the only one?
Auto body shops should watch for standard active air dam, grille shutters in 2019 Ram 1500
The next-generation 2019 Ram 1500 possesses what FCA called “class-leading aerodynamics,” but this accomplishment could introduce additional complexity into the collision repair process…
