Looking for truck bed lights
mike90
Looking for a pretty simple install truck bed light. Since I have a hard tonneau cover, I would like something to light up the bed even when the cover is closed. Would prefer something wireless, battery operated, that I can just easily click a switch on when I open the tail. Nothing too fancy. Thanks in advance!
Le_Slacker
London, Ontario
Amazon has a lot of led strips kits available
I wired mine into the existing bed lights (which don’t light much) so now everything comes on when open tailgate or hit the unlock button
mike90
I don't have any existing bed lighting in my truck? Where exactly did you wire it to?
ferraiolo1
North Central PA
Le_Slacker
London, Ontario
I popped the optional bed lights installed by the dealer and spliced into those wires
You have a cargo light about the bed/rear window. That light is wired to the tailgate opening/closing
Just need to find that wire!
asgadf/lkjnadsfg
I keep a headlamp in the truck. It's wireless, battery operated, click of a button, powerful, requires no install, and you have both hands free. Just a thought.
Glenn54
Deep East Texas
I’ve used this on past trucks. Works well
Truxedo 1704998 Truck Luggage B-Light Battery Powered 18" Tonneau Lighting System All Vehicles - Truck Luggage - Battery Powered truck bed lighting system 18",Black https://www.amazon.com/dp/B00BKWTGHK/ref=cm_sw_r_cp_api_glt_fabc_Y4BX6C1QDZCGP1GD16RZ
This is what I used as well. It works pretty good but I'd need to add another to the front part of the bed if I frequently needed light in the back and front of the bed.
Whoa_Ram
Azle TX
There are few posts about that wire. I installed the factory Mopar bed lights and used a YouTube video that shows how to wire it so you don't have to take it to the dealer to activate it.
mike90
The wire has to go all the way into the cab right?
Whoa_Ram
Azle TX
Yes. There are plugs that you use to get access to inside the cab. It's pretty easy and in my opinion it doesn't look bad at all if you zip tie it up around the other wire harnesses.
LaxDfns15
Memphis, TN
If you want more of a permanent solution with the hardwiring I used the same kit @Andymax linked to. Combine that with the Curt harness that adds a 5 pin to your 7 pin, and you don't even have to splice into the wires. Just connect the Curt harness behind the bumper after you've wired everything up.
gwatt86
You have any pics of yours installed? Also, how often do you change batteries? For my use, I wouldn't have this on for more than 5-10 minutes but I'm guessing the hot/cold would wear the batteries down more than use.
Andymax
5thGenRams Supporter
Columbus, OH area
Don't think for a minute that either splicing into the trailer hitch wiring, or using one of those Curt adapters is even remotely difficult. It's easy.
I used the time-delay relay specifically because I know I would accidentally forget to shut it off, thus killing the battery, plus I didnt want to have to have the key handy to turn it on.
Just saying, this is not a difficult job if you even remotely handy.
Glenn54
Deep East Texas
mike90
Do you have a link to the Curt harness you’re speaking of?
Jako
Borough of Parks
curt 56584 or 56070
56584 is for 5 wires and 56070 is for 7 wires. If you use the 7 it will give you an auxiliary "hot" wire but you will have to shorten the wires as the 56070 is used for a fifth wheel.
mike90
curt 56584 or 56070
Thanks for the link! Can you define what auxiliary hot is? Is that where it only comes on when the truck is on? I assume I wouldn’t want that if I wanted to turn the bed lights in when the truck is off. So which wire did you wind up connecting your lights to. I want to avoid draining my battery as well in case I left them on. Thanks in advance!
