Mountain Whiskey
- Mar 2, 2021
Darn. I just gotround wheels with my Bighorn. ☹
I don’t know 100% what it is, yet. I’m going to look after work. My 21 is definitely different than the 22.Well, I guess you have aftermarket exhaust tips. I don't believe you can weld a painted part without the paint burning off but I'm not a welder...so maybe I'm wrong.
Nope. That weld is definitely done after plating. There's heat tinting on the plating. I wasn't sure they if they were black chrome or painted until I adjusted the exhaust tips closer to the bumper and saw those welds. If they were painted, they probably would have done it after it was welded.Painted or polished after manufacturing I’m sure.
You're right, it's welded there. But it's attached to the exhaust with a clamp here...This part is welded on.
Yeah, I'm aware of that because I adjusted the tips from that point. I was just pointing out the weld to show what kind of finish was on the exhaust tips.You're right, it's welded there. But it's attached to the exhaust with a clamp here...
