Auto Climate Control Fan Speed - Not accounting for engine temp
firecadet613
I thought I recalled seeing this on here a while back and now I can't find it.
Winter temps finally arrived in my area. Jumped in the truck today - had it set to 72/auto. Fan was blowing full blast, cold air at me. All other vehicles with auto climate control have ran the fan on low until the engines warmed up enough to let it spit out hot air and then sped up the fan.
Has anyone else experienced this?
VaderRebel
Canada
Yep, full blast until I open the drivers door... then the fan speed drops a bit... but it gets warm quick.
sticker500
Yep same thing here, they should actually by diverting the air to the top vents and on low. They need some work on the programming
Edwards
TX
Yes, and while I'm a big fan of fan speed in the summer, I'm a bit shocked at how fast fan speed 1 (lowest) is. Until it warms up, that's a lot of chilly air coming at you.
Wish there was more spread between slowest and fastest speeds.
firecadet613
Mine is full blast on both remote start and regular start. On my F150 it ran full blast on remote start but once I got in, slowed down until it warmed up.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
That kind of intelligence makes sense...and should be totally programmable. It’s inexcusable to have it take several minutes for the system to react (at all) to ambient conditions.
RBRK
Salt Lake City, UT
Whoever programmed the HVAC screwed up. The thing is a mess. I’ve never had a vehicle with so many missed screw ups etc. I always buy first year stuff and this one by far has more weird stuff than any others.
The 4th gen never blew until it got,a,little warm at least.
Maybe someday they will get around to fixing it.
Oh ya I need a windshield too. Quit hoarding all the parts for new builds FCA!
Ram Cares ? Just for sales obviously. After the sale, not so much.
fact mechanic
Yes. It’s cold.
silverbullet
Anyone else still having this issue? Know of a fix? It's annoying and yes if you turn the fan speed down manually that does the trick but what's the point of "Auto" if it needs so much damn attention, haha.
riccnick
Southwest Florida
In the November Uconnect update, the HVAC logic was updated to run on full blast when remote started, and then when the driver completes takeover (pushes the start button), the HVAC fan will activate the comfort feature. This prevents a long cabin warmup time, but also allows the driver to not be blasted when they get into the truck. The comfort feature is now also active during every normal start (not using remote start).
firecadet613
Was this for the 8.4" display as well?
riccnick
Southwest Florida
Not sure if the update came out at the same time, but I imagine the logic should be the same. I specifically remember noticing the difference in mine immediately, because, like a lot of others here, it bugged the crap out of me when it blew cold air for 15 mins for no reason. My 2001 (18 years older!) Audi had the comfort feature and was smart enough to not blast you with cold air.
firecadet613
Last I checked my uconnect was up to date...is it a box you have to check? An option to have it on or off? This bugs the crap out of me as well...never an issue with my F150.
riccnick
Southwest Florida
It was the last (and only as far as I know) Uconnect over the air update that my truck received. Pretty sure it was November time frame. You can always enter your vin in the Uconnect Update website to see if there's anything you haven't had updated. (Not that the Uconnect site is very good though....)
Just a little note for everyone, it's important that you MUST be using the auto setting (I'm hoping this is obvious). Using the defrost, mix, or custom fan speed overrides this feature. When its super cold but I want my defrost on, I get in the truck and push the front defrost button and then push the auto again, it sets the system to auto defrost instead of the regular blast your face off defrost.
firecadet613
Has to be an update for just the 12" screen. Mine has never updated and last I knew it was up to date - confirmed on the website just now.
I'm waiting to hear back from others if the HVAC recall/flash fixes it.
silverbullet
I don't have nav on my 8.4 so I don't think it can even get OTA updates. I'll have to mention an update to the dealer on my 1,234,568,699 trip to the service department. As much as I hate to admit my mistakes buying a very early build truck from FCA was not a good idea at all. I knew I'd have to deal with some stuff but the patience wears thin after a dozen trips. Some of it is out of their control but wow did the law of averages screw me on this one...
Boozygoose
SW Florida
I have a 12" screen, late October build and Uconnect reads up to date and while I live in Florida so it isn't the end of the world, that cold blast still happens. Hasn't changed for me. It's not crazy cold here but 60 degree morning with cold air blasting out of the vents? It is definitely odd. I realize I could just turn it off, adjust or remote start but first vehicle I have ever owned with "auto" that technically means I have to "automatically" remember to turn it off when I hop in the truck until it is warmed up.
