Whaddya know, it does! Woohoo! It turns out mine was made on a Wednesday!Bottom of the window sticker will have the month and date, mine is shown here as 0514 for May 14th.
Awesome, I love coming here and learning new things.Bottom of the window sticker will have the month and date, mine is shown here as 0514 for May 14th.
Awesome, I love coming here and learning new things.![]()
Interesting. My window sticker shows 0713 Tuesday and my door sticker's MDH shows 070923 Friday. Which is few days difference. That was during a shutdown so, maybe the truck sat with a door sticker then they printed up the window sticker when they got back to work.Bottom of the window sticker will have the month and date, mine is shown here as 0514 for May 14th.
july 9 at 11pm was a friday night and if there was no work on saturday july 10 that would probably make a differenceInteresting. My window sticker shows 0713 Tuesday and my door sticker's MDH shows 070923 Friday. Which is few days difference. That was during a shutdown so, maybe the truck sat with a door sticker then they printed up the window sticker when they got back to work.
That is a very plausible explanation and makes complete sense. Mahalo.I pretty sure I read somewhere the door jam is the date it comes off the build line and the window sticker is when it gets/ passes final inspection.
My MDH is 23 and the window sticker is 29.
My door sticker is 0720, but the window is 0708 (based on the VIN lookup generator, since I don't have the original window sticker). Hmmm.I pretty sure I read somewhere the door jam is the date it comes off the build line and the window sticker is when it gets/ passes final inspection.
The 18 is for 6:00PM M month D day H hour or MDH. LaterMine was done on Tuesday 11/13/18. Almost 3 years ago. Hard to believe I've had this truck almost 3 years already!
you do not need your window sticker just put your vin after the = sign here;My door sticker is 0720, but the window is 0708 (based on the VIN lookup generator, since I don't have the original window sticker). Hmmm.
I never seen a build sheet that says active air dam delete?!Bottom of the window sticker will have the month and date, mine is shown here as 0514 for May 14th.
Nope. Mine only has the day and month. I know it was 2018 because I bought it in January 2019The 18 is for 6:00PM M month D day H hour or MDH. Later
Thanks - that confirms that the window sticker is 0708, but the door is 0720.you do not need your window sticker just put your vin after the = sign here;
You mind posting a few pics of what they replaced that with or do you just have open space under there
