Basically the same here as well. If hot or in direct sunlight, I will typically only wash half at a time leaving the side exposed to the sunlight for last. It has been years since I've owned a black vehicle, and I've never owned a vehicle as large as my RAM, so it took a few washes before I found an approach that worked with good results lol.I do the same as Wgm. When it’s hot, I section the truck and work on 1/3 at a time so the soap won’t dry
I’m not 100% convinced that it really helps (but I still do it).does foaming work ?
I prefer it to a pressure washer for the initial rinse. Less harsh on the paint and does a better job lifting heavily soiled panels.does foaming work ?
For the money, I've had very good results from the TriNova. MTM PF22.2 if you want probably the best you'll find.What are some good foam cannons out there? Been tossing around getting one before car wash season starts up.
Honestly, there is the MTM PF22 and then there is everything else. The MTM is expensive, but amazing. If you don't want to spend that kind of money on a foam cannon, a 20 dollar one from Amazon will do the job. The rest in between are just fancier packaging.What are some good foam cannons out there? Been tossing around getting one before car wash season starts up.
The TriNova is a lot better than the Amazon specials, especially with a 1.1mm orifice. I'd probably recommend it over the MTM for most people.Honestly, there is the MTM PF22 and then there is everything else. The MTM is expensive, but amazing. If you don't want to spend that kind of money on a foam cannon, a 20 dollar one from Amazon will do the job. The rest in between are just fancier packaging.
That's one of the few I haven't tried.The TriNova is a lot better than the Amazon specials, especially with a 1.1mm orifice. I'd probably recommend it over the MTM for most people.
I bought one off amazon 3 years ago for $20 and it's worked perfectly. It has all brass and stainless construction except for the obvious plastic parts. I use it 2-3 times a month except when it's below freezing. I definitely think there's diminishing returns as the price goes up which something like this that's basically a commodity.What are some good foam cannons out there? Been tossing around getting one before car wash season starts up.
