Morenar
Did your ride change much with the 3.5 and the 22"s?I have the 3.5” Readylift and just put on some BMF Payback wheels. 22x10.5
No rubbing or trimming
Im installing my RC 3.5 tomorrow. No wheels or tires yet but I am leaning towards 295/60r20s.that is the exact set up im running as far was wheels and tires. im getting the 3.5 RC lift installed soon
That’s great I’m waiting for my rough country lift kit myself as my mechanic is going to install it on my Dodge Ram Laramie 1500.I am waiting for my new truck to get here and am ready to start getting some accessories purchased to install as soon as it comes in. I have been looking at the Readylift 3.5" SST kit and the Rough Country 3.5" kit. They seem almost identical but there are a few differences. I am trying to get some feedback on these kits from people who may have either one. Here are a few of the main differences:
* Rough Country is $300 cheaper
* Rough Country comes with Rear Shocks. Readylift says it doesn't need new longer travel rear shocks.
* Rough Country uses a max tire of 295/20/20. Readylift says you can go 35x12.50/20 with a +18mm offset. Not sure if this is realistic.
Both kits seem to have good reviews and should be well made. My main concern is keeping a quality ride. I am planning on putting fuel Mavericks on it, with an AT tire.
Any feedback is welcomed.
Thank y’all for responding to my threadThat’s great I’m waiting for my rough country lift kit myself as my mechanic is going to install it on my Dodge Ram Laramie 1500.
The size of the rim shouldn't matter. The overall OD of the rim and tire as well as the rim offset will determine if you have any clearance issues. Most aftermarket rims will have more negative offset and stick out a little further.I have my 33” tires and factory wheels on my Dodge Ram LaramieLaramie yet I have a question I have a chance to buy a set of 22” wheels and tires so my question is would they rub? The lug pattern is the same as mine. Just was hoping to get feedback because it’s a great deal.
I feel like the Ready Lift has a more quality manufactured rear spacer but I do like the shock upgrade options on the Rough Country. I'm not a big fan of putting spacers on the strut assembly. So far I have ridden my RC 3.5 for 5 days. Still rides the same, no alignment needed. Haven't noticed much change in the handling but once I get my wheels and tires mounted I will post pictures and an update on how I am liking the kit.Hi l'm looking for some help which is the better lift ready lift or rough country. thank you
Sent from my SM-N975W using Tapatalk
So I should get in touch with the guy I’m buying the 2/“ wheels and tires off of and see what offset the wheels are?The size of the rim shouldn't matter. The overall OD of the rim and tire as well as the rim offset will determine if you have any clearance issues. Most aftermarket rims will have more negative offset and stick out a little further.
So you just did the RC with the shock upgrade? I was recommended this one over the Readylift by my suspension shop because the readylift is just spacers and the RC you get shocks.I feel like the Ready Lift has a more quality manufactured rear spacer but I do like the shock upgrade options on the Rough Country. I'm not a big fan of putting spacers on the strut assembly. So far I have ridden my RC 3.5 for 5 days. Still rides the same, no alignment needed. Haven't noticed much change in the handling but once I get my wheels and tires mounted I will post pictures and an update on how I am liking the kit.
My mechanic get Rough Country for all the dealership here where I live gets him to use Rough CountryI feel like the Ready Lift has a more quality manufactured rear spacer but I do like the shock upgrade options on the Rough Country. I'm not a big fan of putting spacers on the strut assembly. So far I have ridden my RC 3.5 for 5 days. Still rides the same, no alignment needed. Haven't noticed much change in the handling but once I get my wheels and tires mounted I will post pictures and an update on how I am liking the kit.
The size shouldn't matter, That's what she said ! Have an awesome weekend.The size of the rim shouldn't matter. The overall OD of the rim and tire as well as the rim offset will determine if you have any clearance issues. Most aftermarket rims will have more negative offset and stick out a little further.
I’m picking up the 22” wheels and tires in the morning went by my mechanic shop and the Rough Country level kit is in. Yet with the 22” tires do I need a leveling kit?That’s great I’m waiting for my rough country lift kit myself as my mechanic is going to install it on my Dodge Ram Laramie 1500.
Thank you b I showed them to my mechanicWhat size offset should you choose if you want the tire to stick out 1" past the fender with out using wheel spacers?
My mechanic got my rough country level kit in so I got my 22” wheels and tires and should no have them mounted before I do the leveling kit first?Thank y’all for responding to my thread
