reyna12682
- Sep 19, 2018
has anyone done a subwoofer swap on an alpine system? i know the old ones were swapped with pioneer but i was curious about the new ones.
This looks like a pretty sweet option to swap out the door speakers with a better set of components. I feel like the highs are lacking on the factory Alpine system.Take a look at the RockfordFosgate 100 watt mini's... You install them next to your speakers (i.e. in the doors) and install the speakers into them.... Then you don't have to run new cables to your speakers. https://rockfordfosgate.com/products/details/pm100x1k/
If you need better highs do the jbl gx302 in the dash.This looks like a pretty sweet option to swap out the door speakers with a better set of components. I feel like the highs are lacking on the factory Alpine system.
Lol just did it this past weekend, definitely what the alpine needed. Crutchfield had them on sale so o picked up 2 pairs with adapters for 79 dollars shipped . Have you considered doing the 2 in the head liner in the back ?If you need better highs do the jbl gx302 in the dash.
Helps the HK system alsoLol just did it this past weekend, definitely what the alpine needed.
I would contemplate upgrading these, if I knew they would be as easy to swap as the dash speakers. Don’t want to screw up the headliner trying to remove the grill covers.Have you considered doing the 2 in the head liner in the back ?
I read somewhere people saying it was a 2.5” speaker instead of 3.5. They won’t be to much it’ll def make it sound much better back there.They are identical to the dash speakers on both the alpine and hk systems, my concern is they would be too much for rear passengers because of their location.
I would havent thought there would be a large difference on the HK, since those speakers have an actual tweeter, the 3.5 in the alpine is just a mid driver. Crap for anything above 4k. CD technologies makes 2 ohm 6x9s might look into some of those for the doors nextHelps the HK system also
I think page 4 of the attached document breaks down the 3 systems into more detailsI read somewhere people saying it was a 2.5” speaker instead of 3.5. They won’t be to much it’ll def make it sound much better back there.
Awesome. I’ll replace them then. Guess I’ll order another set of jbl gx302 and throw them in. The alpine in my personal opinion is a lot better than HK I work at a dodge dealership and hear both of the systems and the alpine sounds so much betterI think page 4 of the attached document breaks down the 3 systems into more details
Triple voice coil, 2 ohm coils shallow mount, Everyone makes one of those, lol.The stock alpine sub is a triple coil design. Very rare. Gonna make it hard to swap
I know right lol. I'm gonna do a single 10" dvc 2 ohm sub under seat on factory amp. Sick of listening to back window rattling.Triple voice coil, 2 ohm coils shallow mount, Everyone makes one of those, lol.
Probably going to have to add a load resistor on the unused channel so the amp at least thinks its connected otherwise it will probably shut down all three channels thinking there's a problem with the subwoofer, because there is a problem...its gone.I know right lol. I'm gonna do a single 10" dvc 2 ohm sub under seat on factory amp. Sick of listening to back window rattling.
Yes i figuired that. I'm wondering how much power that amp really makes per channel. I might be able to fit 3- 6.5 or 8" subs under there tooProbably going to have to add a load resistor on the unused channel so the amp at least thinks its connected otherwise it will probably shut down all three channels thinking there's a problem with the subwoofer, because there is a problem...its gone.
Three 8s now theres an idea.Yes i figuired that. I'm wondering how much power that amp really makes per channel. I might be able to fit 3- 6.5 or 8" subs under there too
